pk
| posted on 31/10/05 at 01:24 PM |
Paint what the experts / pros are using
Ok - all you pro painters out there. What's the best solution / system to use when painting the undersides of new steel wings? should all that
thin black paint (is it paint - called Phosphoretic?) be removed? or is a good dry prep good enough to key? Should we be using 2 part epoxy primer
followed by 2 part epoxy gloss? Or is there a better system?
| posted on 31/10/05 at 02:48 PM |
Cataphoretic?
You can paint over it with solvent or waterbased paints, no problem but on the underside you might be better off with waxoil or ziebart type product.
I'm not a pro so I use ruberoid type paint from Wickes or similar under mine.
Mark Allanson
| posted on 31/10/05 at 10:13 PM |
Just colour the outside and wax the inside
