jonbeedle
| posted on 21/11/05 at 06:01 PM |
Fuel filler and cap... thinking out loud!
Not sure how to do this. At the moment I have a temporary bung type fuel cap stuck in the top of my tank. I have bought an MG Midget locking fuel
filler neck and cap which is 2 1/4" OD. The ali pipe welded to the top of my tank is 2". Is there a rubber fuel hose available that will
step up from 2" to 2 1/4"?
Alternatively I have an ABS plastic Durapipe reducing connector (BS5392/1) which I could fit between the tank and filler using some sort of sealant
or
I could always fit a bit of 2" rubber fuel pipe and then fit a screw cap but would I then need a locking boot cover for the SVA?
I'm looking for the cheapest easiest solution!
Your thoughts and comments would be appreciated.
Jon
[Edited on 21/11/05 by jonbeedle]
"Everyone is entitled to an opinion however stupid!"
Deckman001
| posted on 21/11/05 at 08:00 PM |
I've used a mini locking cap and tube, this is over 2" but a £2.50 bit of 2" filler tube from Rally design fitted both ends no
problem The tube is 25 pence per cm and all you need is the bit to join the two different parts
Very locost
Jason
jonbeedle
| posted on 21/11/05 at 11:33 PM |
Cheers Jason
