Danozeman
| posted on 29/12/05 at 07:57 PM |
Bonnet mounting.
Iv had a search and cant find anything.
Is there anyway i can mount the bonnet with out having anything showing?
Just thinking about nice clean lines.
Dan
stevebubs
| posted on 29/12/05 at 08:09 PM |
aerocatch is probably the best way, or the westfield mechanism...
Danozeman
| posted on 29/12/05 at 08:13 PM |
aerocatch?
Dan
John Watts
| posted on 29/12/05 at 08:44 PM |
Yes, Aerocatch.
See here and here
Second link doesn't seem to be working at the moment.
stevebubs
| posted on 29/12/05 at 09:04 PM |
Try this one
Available Here, Here and
Here
[Edited on 29/12/05 by stevebubs]
stevebubs
| posted on 29/12/05 at 09:08 PM |
BTW Doesn't solve the problem with things showing, but does give you nice smooth lines and SVA friendly.
Only other option I can think of would be to have a release system similar to a tin-top....but I think you'd have to bastardise an existing
install or make one yourself from scratch - nothing like this available "off the shelf"
stevebubs
Just had a thought - you could always use a couple of solenoids / electric door locks that release when you press a button....
Danozeman
| posted on 29/12/05 at 09:26 PM |
I like them aerocatches. Too pricey though. The solenoid idea is good and flash but hard to rig up. I like easy stuff.
I was thinking maybe a hook either side at the front and some sort of catch at the rear. But its fitting it all to the bonnet securly.
Dan
stevebubs
| posted on 29/12/05 at 09:32 PM |
Hmm....deadbolt operated from within the scuttle?
Avoneer
| posted on 29/12/05 at 10:00 PM |
Westfield - invisible lug at each side at the front into the nose cone and two key holes on each side at the back that spin a lug on the inside.
Pat...
piddy
| posted on 30/12/05 at 02:32 PM |
Just found this link that may be of use.aero catch
Simon
| posted on 30/12/05 at 08:04 PM |
I was going to go the "tintop" route by using the catches from a "classic" range rover - it has 2 connected by a wire, but it
would have meant more delays while I made (laid) up mountings for the pins inside the bonnet.
Bonnet remake may well end up with them!!
Simon
Danozeman
| posted on 3/1/06 at 06:56 AM |
Cant decide. I like the aero catch but out of my budget. Its looking like dzus or rubbers at the min.
Has anyone any pictures of the westy way?
[Edited on 3/1/06 by Danozeman]
Dan
stevebubs
| posted on 3/1/06 at 09:24 AM |
No pics but the westie catches are about £35.
