Howlor
posted on 2/1/06 at 05:30 PM |
Bending fibreglass - Possible?
Hi all,
I may be wrong here but I recall someone mentioning to me that you manipulate the fibreglass by heating it up with a heat gun. Does this work? I have
thrown all of my spare bits to try it!
Thanks,
k33ts
posted on 2/1/06 at 05:33 PM |
it does work but if your not carefull it bubbles if it gets to hot.
Howlor
posted on 2/1/06 at 05:39 PM |
I suppose the only option is then to bubble the rest of the car!
k33ts
posted on 2/1/06 at 05:42 PM |
i suppose if you want something that bit different.
zxrlocost
posted on 2/1/06 at 05:53 PM |
I suppose I wouldnt bother
k33ts
posted on 2/1/06 at 06:06 PM |
i suppose your right
Hugh Paterson
posted on 2/1/06 at 06:07 PM |
Mmmmm it tends to go woof with a bit to much heat
Shug
RichieC
posted on 2/1/06 at 06:38 PM |
Howlor, which part is it your looking to bend?
I remember Marc spoke about it in a thread previously when discussing the nose-side panel fit
Rich
crbrlfrost
posted on 2/1/06 at 06:44 PM |
It depends on the resin used. Polyester based resins are a thermoplastic, and will soften and bend with heat applied up to an extent. To much heat
will result in the aforementioned blistering and destroying of the resins properties. If epoxy is used, it is a thermoset resin, and will continue to
harden with the application of heat (post cure if you will) until its max temperature is reached and then it will melt (not in a good pliable way).
Cheers!
Howlor
posted on 2/1/06 at 08:47 PM |
Rich
I am looking to bend the side panel where it meets the rear panel. The radii are not the same on each panel so wondered if I could just tweak them a
little to get a better match. Also looking to sort out the side panel fit to the nose cone underneath.
Thanks,
RichieC
posted on 2/1/06 at 08:52 PM |
This is the thread I was thinking of.
Do you have any pics of what it is you are trying to do, I note a few people have mentioned fitting the nose to the sides
Rgds
Rich
Triton
posted on 2/1/06 at 10:39 PM |
Depends what you are after doing, but it is possible to alter the shape. Clamp it where/how you want it then something like a painters oven with a bit
of warmth rather than direct heat......it does work as ong as you don't go mad.
www.tritonraceseats.com
www.hairyhedgehog.com
