| posted on 25/1/06 at 02:30 PM |
show me your boot!
or to be more precise, the small area behdind the driver and above the pertol tank!
I removed the ply boot floor and will be replacing with aluminium, 1.2 or 1.5 mm, and just looking for ideas so I get it right-ish first time.
Thanks.
muzchap
| posted on 25/1/06 at 02:38 PM |
Hi mate,
My mate did his with alloy and it constantly rattles :-(
I'm going to use Fibreglass ;-)
Murray
smart51
| posted on 25/1/06 at 02:41 PM |
MNR do a GRP boot box which may fit.
I've seen a boot that was formed in chicken wire and then covered in wet fibreglass. Once carpeted it looked alright (in the dark)
balidey
| posted on 25/1/06 at 02:54 PM |
there are two Westfield GRP boot boxes on e-bay now, may be a good starting point?
Humbug
| posted on 25/1/06 at 02:55 PM |
I made a template out of cardboard, the cut the same shape out of ali (1 piece), folded and riveted it, and self-tappered it to the chassis. My boot
is a bit narrower than some because I have lights on the back panel.
See my photo archive for pics
| posted on 25/1/06 at 03:07 PM |
that's the lines I am thinking on; will use lots of silicone sealnat to ensure no rattles
flyingkiwi
| posted on 25/1/06 at 04:47 PM |
Sorry to hijack but whats the score with a boot floor and SVA? Does the boot have to be removeable?
I plan on covering in the bottom (got a big sheet of Titanium) to *obtain* some ground effect, so with a fixed boot mr SVA won't be able to see
in there.
Chris
It Runs!!!!! Bring on the SVA!
Phil. S
| posted on 25/1/06 at 08:56 PM |
I made mine out of 1.2mm aluminium and have no rattles. There's a couple of pictures
at the bottom of this page
"The unexamined life is not worth living" (Socrates)
"The unlived life is not worth examining" (Kopp)
Simon
| posted on 25/1/06 at 11:04 PM |
Phil,
Very neat
SImon
NS Dev
| posted on 25/1/06 at 11:41 PM |
very neat indeed!
Hasse
| posted on 26/1/06 at 11:05 AM |
Made mine out of 1.5 mm alu, splitted in two for easy removal. Screwed on the sides and "resting" on top of the tank with foam rubber
between.
No rattling.
Last pic in my archive.
/Hasse
andyharding
| posted on 26/1/06 at 12:06 PM |
Nope, doesn't need to be removable.
in there.
Chris
| posted on 26/1/06 at 12:58 PM |
We made ours from 6mm plywood and then covered in carpet. Undo four screws and the whole boot can be removed.
Boot Box Here
Mark Allanson
| posted on 26/1/06 at 01:53 PM |
A picky with the lid off
Mark Allanson
..and one with the lid on
