omega 24 v6
posted on 12/2/06 at 10:39 PM |
Nose cone
Ok who has fitted a std nosecone to a 442 and how?
Does a std one fit for width? I'm not so worried about height at the moment as I reckon anything I but will prolly need a bit of fettling and
filler to make it fit. So anyone got an answer ? or photo's would be good too.
Thanks in advance.
dave1888
| posted on 12/2/06 at 10:48 PM |
I think criag1410 has some in his archive
[Edited on 12/2/2006 by dave1888]
Volvorsport
| posted on 12/2/06 at 10:50 PM |
fits for width at the front , but not at the back !!
www.dbsmotorsport.co.uk
getting dirty under a bus
James
| posted on 13/2/06 at 11:16 AM |
Couple of questions: the 442 is 2" wider at the 'L' assembly?
Are the 'J' rails at the same angle as a 'Book' chassis?
Assuming yes to both these I guess you could just slide a standard nosecone forward of where it should be, up to the point where the sides of the nose
are inline with the chassis rails.
My chassis is 1.75" wider in this area (my 'L' assembly is book but the 'J' rails are 1.75" wider) and I've
managed to fit a standard nose just by sliding the nose forward.
This obviously makes the side panels harder to do but this can be overcome.
Hope that helps,
James
- Muhammad Ali
JohnN
| posted on 13/2/06 at 05:48 PM |
I've fitted a Luego Velocity nosecone to my 442 chassis, no real problems. Upper suspension mounting points are obviously 2" lower than the
moulding expects and the bottom of the chassis is visible.
Width - wise it fis OK
