Author: Subject: Success!!!
stevebubs
posted on 12/3/06 at 09:41 PM Reply With Quote
Success!!!
Popped what I hoped to be the final part out of the mould today...Came out pretty good if I say so myself.
Second Bulge
Second Bulge
Only trouble is it's slightly the wrong colour
donut
posted on 12/3/06 at 10:07 PM Reply With Quote
Yeah that looks good!!..erm what is it?
Avoneer
posted on 12/3/06 at 10:10 PM Reply With Quote
Looks really good mate.
Did you use wax in the end?
Pat...
stevebubs
posted on 12/3/06 at 10:49 PM Reply With Quote
It's a friggin great bulge for my fury bonnet.
Pat - Yes, I used wax in the end.
Humbug
posted on 12/3/06 at 10:59 PM Reply With Quote
How big is it (oo-er!)? - I mean the bonnet bulge
I might be in the market for something like that...
muzchap
posted on 12/3/06 at 11:02 PM Reply With Quote
Looks good mate - some perserverance there!!!
I remember seeing the 2 tonne filler version way back in December
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
posted on 12/3/06 at 11:27 PM Reply With Quote
Which end would that be? I bet you're not going into production after the time it's taken to get that one done .
stevebubs
posted on 13/3/06 at 12:26 AM Reply With Quote
Approx 22in x 22in - will measure more accurately tomorrow for you.
The one in the picture is scuplted to the Fury Bonnet. However, I do have a buck that's the same shape but designed to go on a flat surface.
[Edited on 13/3/06 by stevebubs]
stevebubs
posted on 13/3/06 at 12:29 AM Reply With Quote
Actually, making the parts are easy - it's the blooming buck I've had trouble with. However that's done now..the part pictured above took about 2 hours work in laminating and gelcoating (over about 10 hours). Shining it up took about 30 minutes. Not a perfect finish, but not too bad.
Need to try and get a better colour match, so will probably be making another as soon as I can get the pigment.
Humbug
posted on 13/3/06 at 07:35 AM Reply With Quote
Cheers... btw, I have just started a new job based in Reading, so maybe I could come and have a look at your bulge sometime (oo-er again!)
ned
posted on 13/3/06 at 07:57 AM Reply With Quote
Steve,
Looks like your hard work is paying off - well done.
Ned.
beware, I've got yellow skin
stevebubs
posted on 13/3/06 at 09:13 AM Reply With Quote
No probs - where in Reading are you working?
stevebubs
posted on 13/3/06 at 12:51 PM Reply With Quote
Colour match in the picture below looks better than it is (bulge is quite a bit lighter than the rest of the car)
[img][/img]
Avoneer
posted on 13/3/06 at 09:21 PM Reply With Quote
Do wet lay CF now that you have a mould.
Use clear gel, one layer of CF and 2 layers of normal CSM.
Polish to gloss finish after.
Pat...
stevebubs
posted on 13/3/06 at 09:23 PM Reply With Quote
Black / CF effect would definitely be an option.
Want to see if I can get a good match from West & Senior first, though....
Avoneer
posted on 14/3/06 at 01:33 AM Reply With Quote
I'm gonna wet lay up some small pieces of CF in the next week or two to see what sort of finish I can get.
One with clear gel to polish.
One without.
One under pressure.
One with core matt to ass volume.
Will let you know what happens.
Pat...
