Author: Subject: Louvers, will they pass SVA
mark chandler
posted on 29/3/06 at 08:46 AM Reply With Quote
Hi Chaps,
I,m starting to think about panels now the frames nearly complete.
I,m planning to have a flat bottom right across the frame and put in louvers to vent in both bonnet, side panels and floor section behind the rad.
Are Louvers SVA friendly or do I need to leave these off until I have submitted for a test ?
Regards Mark
posted on 29/3/06 at 09:27 AM Reply With Quote
They are acceptable but it depends on the gap. As the gap gets bigger, the edges need to be radiused; for small gaps, blunted eges are required.
scutter
posted on 31/3/06 at 04:53 PM Reply With Quote
Mine are fairly standard and they passed SVA test, I covered them and was asked why as they didn't need them.
matching helmet
matching helmet
ATB Dan.
Mark Allanson
posted on 31/3/06 at 05:44 PM Reply With Quote
Only projections facing forward are suject to the 2.5mm rule
posted on 31/3/06 at 06:14 PM Reply With Quote
Did you make your own louvres Scutter? Any tips would be appreciated
scutter
posted on 31/3/06 at 07:03 PM Reply With Quote
No I what's commonly called paid through the nose for them, pro job cost me £120
ATB Dan.
iank
posted on 31/3/06 at 07:22 PM Reply With Quote
If it's any consolation they do look very professional.
Triton
posted on 31/3/06 at 07:25 PM Reply With Quote
Very smart and not easy to do neatly without the right kit
www.tritonraceseats.com
www.hairyhedgehog.com
