ReMan
posted on 11/4/06 at 09:45 PM |
Grille mesh
Grille mesh
I have made , but not fixed the grille below.
I have been advised , that it may not offer enough airflow to the rad.
Any experience or thoughts on this, before I give it to the wife for making spaghetti?
www.plusnine.co.uk
RazMan
posted on 11/4/06 at 09:52 PM |
I was tempted by this design but when you look closely it has more metal than holes - which must be a bad thing for airflow. In the end I went for the
conventional diamond mesh which appears to flow better.
I suppose it wouldn't hurt to try it
[Edited on 11-4-06 by RazMan]
Raz
Chippy
posted on 11/4/06 at 10:24 PM |
Considering the b***dy great hole in the front of the Locost nose cone, I would think that you would have no problem with the grill shown. As
it's fairly easy to remove the nose cone, why not just try it, if it gets too hot whip it out and fit something less filling, but don't
think you will need to. IMHO. atb Chippy
ned
posted on 12/4/06 at 07:28 AM |
Colin,
Looking at your archive it looks like you're using an escort rad which must be larger than the original fireblade one so I would be suprised if
you are short of cooling for your motor with that grill.
Ned.
beware, I've got yellow skin
posted on 12/4/06 at 07:36 AM |
Depends what engine you are using... ZX12R you would overcook the engine!
ned
posted on 12/4/06 at 08:02 AM |
Hellfire, its a fireblade in his archive
ReMan
posted on 12/4/06 at 08:36 AM |
quote: Originally posted by ned
Colin,
Ned.
Yes it is a Blade and I like your logic, so will probably give it a try.
If I fix it in with PU it should come out again if needsbe too.
www.plusnine.co.uk
mandbsheldon
posted on 12/4/06 at 12:22 PM |
That's what i've used on mine
Just before it went bang
Only kidding seems to be fine.
Leigh
posted on 12/4/06 at 01:28 PM |
Colin,
Ned.
surely it doesn;t matter how big the radiator is if you cannot get enough air through?
look nice though but I wouldn't use it; shopping trolley, you know it makes sense.
Really must get round to posting the details about the mesh supplies that I have used in the past....
ReMan
posted on 12/4/06 at 02:55 PM |
Leigh
The temp gauge is being retianed!
www.plusnine.co.uk
ned
posted on 12/4/06 at 03:17 PM |
Colin,
Ned.
true but running a larger rad you need less air flow to get the equivalent cooling as there is a greater surface area to discipate the heat.
Ned.
posted on 13/4/06 at 07:26 AM |
Colin,
Ned.
Ned.
I'm thinking about it but still not convinced. If you take that to extreme, say have a 2 inch diameter hole, then surely no matter how big your
radiator is, you will not get the air flow to move the heated air out?
ned
posted on 13/4/06 at 08:14 AM |
In the extreme I would probably agree with you, but I really think that this is taking it a bit far in the context of this thread. The grill pictured
will be fine, or I'll eat my hat
RazMan
posted on 13/4/06 at 08:28 AM |
The grill pictured will be fine, or I'll eat my hat
Careful Ned, you know you turned yellow when you ate that sombrero last year
Raz
ned
posted on 13/4/06 at 08:30 AM |
posted on 13/4/06 at 08:46 AM |
he heh heh - now it gets interesting
I supply the salt and pepper - to oriigal poster, please let us know what happens!!!
ReMan
posted on 13/4/06 at 10:07 AM |
It's only a grille!!!!
I'll give it a go, its made now!
posted on 13/4/06 at 11:49 AM |
it is not that simple; not only it is cosmetic - it does look nice - it functions to let air through. If it is inadequate, you risk cooking your
engine, possibly damaging it so will cost more than a sheet of stainless mess.
ReMan
posted on 13/4/06 at 09:55 PM |
I was tittering about the eating of headgear
I will see what turns up when I have to fit it...... I can see the potential problrm but maybe the bigger rad and the smaller holes will even
themselves out?
www.plusnine.co.uk
wilkingj
posted on 13/4/06 at 10:25 PM |
Try this chap, he was very helpful to me with a piece fo 1/2" welded stainless mesh. If you want it orientated as diamonds, it will cost a
little more, as its cust form a larger area.
Nice quality mesh.
Still, he is helpful, and not too expensive.
I have no commercial connection other than being a satisfied customer.
Drop him an Email.
alan@porteousfab.co.uk
Best Regards
Geoff
http://www.v8viento.co.uk
