DavidM
| posted on 22/4/06 at 08:00 PM |
Tightening Mirrors
I've now got my mirrors fitted, but the drivers side is very loose where the stalk goes into the mirror housing. I Don't know why as
they're new mirrors, and the passenger side is fine.
Does anybody know how to tighten it up?
Proportion is Everything
jdeatsch
| posted on 22/4/06 at 08:11 PM |
sadly, my first post will be...
You'll have to remove the glass I suspect. The attaching device (devise) is in there.
Jim
(doesn't it just figure that there are no Escort MKII's on THIS side of the pond?)
Humbug
| posted on 22/4/06 at 09:20 PM |
To avoid breaking the glass, you could try easing out the flexible cover to see if thre is an adjuster there. I have what look like the same mirrors
and at the other end there is an adjuster that works with a hex key, so you might be lucky?
DarrenW
| posted on 24/4/06 at 09:42 AM |
On mine (look same as yours) you pull back the gaitor and there is an adjustor inside there. I mounted mine to the car then rolled the gaitor back.
Made adjustments, tightened up and rolled the gaitor back down.
Dont touch the glass end - very easily broken. Take a lot of care when tweaking the mirror aim after tightening up. If you twist the mirror head the
glass will crack.
