andyharding
posted on 26/4/06 at 01:20 PM |
Re-painted rear panel
I decided to fully repaint the rear panel with a different technique (closer to panel and turn up fluid plus fan screws).
I'm quite pleased with the result although it will be easier to see how good it is once compounded/polished:-
Painted rear panel (take2)
Painted rear panel close-up
[Edited on 26/4/06 by andyharding]
muzchap
posted on 26/4/06 at 01:31 PM |
Looking good - after compounding should be smooth like a mirror!
Forgive me if I'm wrong - but that looks like a lot of overspray on the chassis roll bar
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
andyharding
posted on 26/4/06 at 01:34 PM |
No, it's splattered polish my 1st attempt with an electric polisher!
Wouldn't matter anyway as I'm going to have to repaint the roll bar as the powder coat is rusting through
posted on 26/4/06 at 01:46 PM |
good example of sod's law this; not a beetle in sight until you start to spray - see you've managed to catch 3 on the white stripes
andyharding
posted on 26/4/06 at 02:12 PM |
lol nevermind - the number plate light will hide the beetles!
Doesn't look it on the photo but the racing stripes are silver and the blue is metalic. Looks loads better in the flesh.
Once it polished I'll try and get some good pics.
Making myself wait until tomorrow to give the paint 24hrs to dry before I start polishing.
Bluemoon
posted on 26/4/06 at 02:18 PM |
What size compresser have you used? I'm thinking of painting mine at some point..
andyharding
posted on 26/4/06 at 02:22 PM |
A 1.5HP 6L £50 jobby from B&Q.
TBH it's stuggling to keep up but with a 1.2mm gun I'm (only) just about getting away with it.
I bought it to power a ratchet when I was at the stage of constantly taking suspension on and off and I'm suprised it has the poke to spray.
Would really like a 100L Clarke Industrial one but don't think the garage power would cope.
PaulBuz
posted on 26/4/06 at 04:32 PM |
Spooky!!!!
Paul
PaulBuz
posted on 26/4/06 at 04:33 PM |
Again
Paul
PaulBuz
posted on 26/4/06 at 04:35 PM |
prep.
Paul
posted on 27/4/06 at 06:50 AM |
quote: Originally posted by PaulBuz
prep.
very last picture showing prep in primer/white - look at those brackets for the seat belt bolts - look quite tall to me - (SVA book gives examples fo
what to do and not to do) - you will get quite a bit of turning moment on those so they need to be welded pretty securlely at the base.
posted on 27/4/06 at 09:38 AM |
or a greenfly, dandelion clock, small spider, wasp etc. If you do get them don't try to pick them off just leave them till the paint hardens,
it's like sweet revenge, then when you cut it back there's only the feet left.
edit:- Wasps love cellulose thinners, they are the glue sniffers of the insect world.
[Edited on 27/4/06 by Peteff]
PaulBuz
posted on 27/4/06 at 03:58 PM |
The harness fixings are the required 450+53mm required.
They are fully welded all round.
The seat is as low as it will go.
What else can I do?!
Paul
