Johnmor
| posted on 4/5/06 at 11:11 AM |
Bonnet Hinging
Has anyone hinged one side of the bonnet pannel so that the bonnet does not have to be removed every time you access the engine bay. Just opened and
stayed in position.
I was considering hinging the bonnet with slip pin hinges so that total removal is easy when required, but i feel the pannel will be easily damaged
with continual removal every time you just want to check the oil.
The hinge side would need to be reinforced and possibly strips accross the width of the bonnet if it flexes too much.
Thoughts please.
smart51
| posted on 4/5/06 at 11:44 AM |
I guess you could use sidescreen type hinges. to be honest, I find removing the bonnet is not a big problem.
Tiger Super Six
| posted on 4/5/06 at 11:52 AM |
Removing the bonnet is fine and I have had no problems.
One thing to remember - when you take it off lay it flat. If you stand it on end the smallest breeze will blow it over and scratch it!!
Mark
Tiger Avon
emsfactory
| posted on 4/5/06 at 11:53 AM |
I found that out the hard way.
muzchap
| posted on 4/5/06 at 12:08 PM |
My biggest tip when removing bonnet is MAKE SURE YOU SECURE THE FCUKA BACK ON
My mates bonnet came flying off and damaged it a bit
Ooh and glad you've spoken like a 'TRUE' Alfa owner - only you guys would consider the 'hinge' requirement - Alfa =
bonnet lifter
[Edited on 4/5/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Johnmor
| posted on 4/5/06 at 01:34 PM |
Ooh and glad you've spoken like a 'TRUE' Alfa owner - only you guys would consider the 'hinge' requirement - Alfa = bonnet
lifter
And of course Ford has always been at the edge of performance and style!!!
Humbug
| posted on 4/5/06 at 02:22 PM |
Fozzie has done a nice job of hinging her bonnet in traditional stylee:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=FozzieFrontBonnetUp.jpg
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=August05%20c.jpg
Grahame L
| posted on 4/5/06 at 04:11 PM |
I had a go with my MK bonnet. I reinforced the bonnet across the width with aluminium strips and where the hinges were mounted, but unfortunately it
still cracked the GRP! I know it can be done but depends what the bonnet is constructed of and the amount of work you want to do reinforcing it. I
reverted to the conventional straps in the end!
Simon
| posted on 4/5/06 at 07:17 PM |
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=3engine%202.JPG
Simon
twilightflyer
| posted on 8/5/06 at 07:28 PM |
like the finished result of the bonnet,also like the bipe stored in the roof of your garage,what is it as I am a modeller (radio control)
ray
HOSMAC
