MikeR
| posted on 5/5/06 at 07:47 PM |
How far inside your arches to fit the wheels?
How far inside your arches have you fitted your wheels?
A lot of early cars had the look that the arches stuck out a lot more than the wheels. This is something i'm trying to avoid whilst sorting out
my rear axle.
Are peoples arches within a few mm, a cm, a inch of the wheel rubber if you held a straight edge across the open part of the arch?
ned
| posted on 5/5/06 at 07:58 PM |
Mike i actually have the reverse of the problem you describe! only few mm but need to use a different set for sva when the time comes!
Ned.
beware, I've got yellow skin
MikeR
| posted on 5/5/06 at 10:44 PM |
Well i'm trying to decide how close to the edge i should go. If it ever came to it that i've gone too far i've got a set of old
escort wheels i could use to get through SVA.
Just curious if 1" is going to look silly or not.
Sort of thinking if 1" was a bit silly then i still have the option of using spacers (despite not liking them). With it being Seirra rear end
i'd think an extra 15mm to my capri alloys would put the wheel mounting more in line with its original design location.
Simon
| posted on 5/5/06 at 11:05 PM |
With a ruler pressed against my tyre and reading from outside of arch, I have 5/8ths of an inch. So allowing 1/4" thickness for f/glass, my
tyres are 3/8ths of an inch clear inside arch.
Clear
Simon
