Author: Subject: What front wing stay bolts??
Jasper
posted on 14/4/03 at 08:53 PM Reply With Quote
Anybody know the thread for the three bolts that fix the front wing stays to the Cortina uprights???
chrisg
posted on 14/4/03 at 09:01 PM Reply With Quote
M8................M8!
Geddit?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
chrisg,
posted on 14/4/03 at 09:30 PM Reply With Quote
M8
Still watching you twin
Geddit?
Chris
Jasper
posted on 15/4/03 at 09:18 AM Reply With Quote
Tried an M8, seemed to bind, maybe I've got paint in my thread..... cheers nutter...
eddymcclements
posted on 15/4/03 at 12:21 PM Reply With Quote
They're M8 and usually full of rust. Proper way to sort it is with an M8 tap, but I saw someone solve the problem with an 8.8 high-tensile bolt with a couple of slots ground along its length with an angle grinder. Might clear the crud out OK?
Eddy
chrisg
posted on 15/4/03 at 06:13 PM Reply With Quote
Yes Jasper I had to run a tap through them but they are M8!
Whatever floats your boat, you sad, sad man.
Chris
[Edited on 15/4/03 by chrisg]
Jasper
posted on 15/4/03 at 07:40 PM Reply With Quote
BTW, did u use spacers or just tighten them up as they are a good distance from the uprights
Stu16v
posted on 15/4/03 at 11:50 PM Reply With Quote
Jasper, I've used long M8 bolts fitted/tightened up from the disc side, effectively making studs to fit the wing brackets. Then I have used nuts for the mounting plate to bolt up to, and finally nylock nuts to finish. The beauty of using nuts instead of spacers is that it gives a little bit of adjustablity.
HTH Stu.
eddymcclements
posted on 16/4/03 at 09:06 AM Reply With Quote
Yes - me too. M*8 x 40mm set screws as it happens. If I was doing it again I'd probably try and get 45mm, as it'll give a couple more threads engagement on the Nylocs.
Eddy
Jasper
posted on 16/4/03 at 09:16 AM Reply With Quote
Good idea, just have to dismantle the calipers/discs again, after threadlocking the capilers on!
Ian Pearson
posted on 17/4/03 at 10:02 PM Reply With Quote
Cut spacers to suit.
Jasper
posted on 18/4/03 at 09:43 AM Reply With Quote
Thanks chaps - all sorted..... shame nothing from lolocost ever fits first time....
