Humbug
| posted on 27/5/06 at 08:52 AM |
Bonnet louvres
I bought some ali louvres from B&Q to go on the sides of my new ali bonnet. The original fibreglass bonnet had moulded in vents in the same place,
so I thought I would do the same for the ali version.
What do people think about which way to put the louvres - inwards or outwards? I was just going to put them the obvious way. i.e. outwards with the
holes pointing to the rear of the car, but I turned it over and it looks quite neat the other way - lourvres inwards and the holes pointing to the
front (inside the bonnet). Also, no protrusions to catch things on.
Thoughts?
Fred W B
| posted on 27/5/06 at 09:06 AM |
I much prefer the top pic - inside. Think that T type MG's etc had them that way
Fred W B
Danozeman
| posted on 27/5/06 at 10:00 AM |
inwards look neater.
Dan
RazMan
| posted on 27/5/06 at 10:53 AM |
Much smoother body line with the top version - and better for airflow if they are taking hot air out of the engine bay (no good as air intake though)
Raz
Humbug
| posted on 27/5/06 at 12:22 PM |
Thanks for the replies, chaps... btw Razman, it is for outflow, not intake
mark chandler
| posted on 27/5/06 at 02:25 PM |
For getting rid of air, bottom with the vent gaps to the rear of the car.
You need the airflow disrupted by the louves standing proud to create a vacumn over the cut hole to draw air out.
Regards Mark
Humbug
| posted on 27/5/06 at 02:33 PM |
Regards Mark
aah. I did wonder about that
jack trolley
| posted on 27/5/06 at 03:04 PM |
Plenty of racing cars had inverse louvers. As long as there's a pressure difference
between the inside and the outside air will flow.
