Triton
| posted on 28/5/06 at 09:51 AM |
Full body
Full Body for 7 type cars.
Most will know I have moulds for a body that dates back to 1958,the car is a bit like a Midget/Cobra etc but not.
I have made a start to allow the body to fit the Locost type chassis but...cars like the Mk Indy, Mac#1 R etc would need a whopping 8" arch
extension in each corner........so I put it to the vote.
Mad wide arches ( prefer this route) or make the whole thing wider ?
www.tritonraceseats.com
www.hairyhedgehog.com
Triton
| posted on 28/5/06 at 09:53 AM |
Forgot to mention, the body was originally made up in Sheffield way before I was even a glint in the milkman's eye
MikeR
| posted on 28/5/06 at 10:06 AM |
8" in total or 8" a side?
I think 4" each side isn't too bad and i'd go that way so us people with "normal" and "proper" cars still
have an upgrade path one winter when we're bored & it means you're still keeping the same dimensions to the original.
Triton
| posted on 28/5/06 at 10:52 AM |
Surprised me as doesn't look that narrow until compared against Indy dimensions....It's 8" in each corner! so will end up like an
hour glass when viewed from above....ie: sides wasted in so would look rather tasty.
There is also a grp windcreen frame and a hard top even doors but on a seven that would be a tad awkward as a bit like Cobra doors.
| posted on 28/5/06 at 11:55 AM |
Yep. Really need to see some pictures before deciding.
Triton
| posted on 28/5/06 at 12:35 PM |
This is a copy taken from an old brochure when the body was first done way back in 1958ish
andyps
| posted on 28/5/06 at 04:30 PM |
Split it down the middle and make it wider - Morris Minor style.
Looks good.
froggy
| posted on 28/5/06 at 04:48 PM |
what was the kit supposed to use as running gear originally then? ive got a modified mk indy chassis under my reliant kitten shell and i have mocked
up 5" arch extensions to cover the wheels which are standard et 38 7x15 . the reliant had a 47" track as standard, and tha sierra is
54" so if you need 16" to cover the wheels the car must have been 38" track if im right?
SixedUp
| posted on 28/5/06 at 05:57 PM |
I agree ... split it and widen the whole thing. Putting 8" arch extensions on that would be a crime. Its quite pretty enough as it is
Richard
Mave
| posted on 28/5/06 at 06:05 PM |
Yep, split in the middle, widen it by 12 inches, and add 2 inch arch extensions.
DIY Si
| posted on 28/5/06 at 06:17 PM |
What he said ^. Widen by 10-12" and add some pleasantly blended in arch extension thingies. Should look very nice. And if it ends up being
vaguely lo(w)cost i'll probably even have one off you!
Bob C
This is quite interesting - I was on the lookout for a full body to go on the locost chassis. The wheelbase on my car (which shouldn't be far
off 'book' size) is 52". Do you plan to make it accomodate the 'book' backend? What about a roll-over bar? Flared arches
aren't necessarily bad - the 427 cobra grew out of the AC ace (ended up looking like one on steroids...)
Could this end up as, 1) take the cycle wings & rear arches, screen bonnet scuttle & nosecone off 2) pop new body over the top 3) do up 6
bolts in rivnuts - then away we go.....????
Bob
Triton
| posted on 28/5/06 at 07:11 PM |
Interesting......
It was made to go on a Ford Pop as well as things like the Buckler DD2 at least I seem to remember the fella saying something along those lines.
The rear section is part of the centre tub and will have a boot lid so a roll bar could be fitted but some tricky pipe work from underneath will be
needed if rear stays used......or go forwards as per the Challenger.
Not got a clue how much but certainly not the silly money things like this usually sell at..
locostv8
| posted on 28/5/06 at 09:22 PM |
In the 50s there was a guy who made copies of an early Ferrari. I can't remember the spelling of his name so I couldn't find a copy, it
was Devon(??). The point is that he made his molds adjustable so he could offer different lengths and widths to fit a variety of car chassis. With
some thought You could make the body in 4 sections and the purchaser would merely trim down to get the desired lengthy and width. Then offer add on
flairs or leave the flairs to the purchaser. This would make fitment to a number of chassis and should make shipping easier. At the right price
point I would be interested in a copy. Flairs done in the style of the 427 Cobra would look quite nice on that body though.
[Edited on 28/5/06 by locostv8]
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
miserableoldgit
| posted on 28/5/06 at 10:20 PM |
If you could make my cycle wings I would be grateful; or at least reply to my U2Us.
The AC Cobra looked pathetic and skinny until the wheel arches got massively widened; go with the 8" extensions and blend them in with style.
Youth and vitality are wasted on the young
Triton
| posted on 29/5/06 at 09:00 AM |
U2u on it's merry way..
Triton
| posted on 29/5/06 at 09:10 AM |
Blending in 8" extensions is my preffered route so it gives the body that "hour glass" look when viewed from above. I like the shape
of the Phoenix/Fury etc which have a wasted in centre section.....But this beast will be wider across the arches so no need for specially shortened
driveshafts.
It will be more a hobby than anything else with the way things are now so won't exactly be done next week.
| posted on 29/5/06 at 10:34 AM |
One advantage of splitting in the middle and adding 12" is that some of the larger drivers may fit ?
Viper
| posted on 29/5/06 at 01:22 PM |
only if you made the chassis wider surely, i thought the point was to drop onto a standard chassis?
Triton
| posted on 29/5/06 at 03:22 PM |
Cockpit opening is 42" x 32" surely big enough?....The Challenger wasn't far off that and some big folk fitted that ok.
DIY Si
| posted on 29/5/06 at 05:35 PM |
It would probably be worth widening the shell, or offering the chance to do so, since so many people are building +4's.
gottabedone
| posted on 29/5/06 at 07:56 PM |
As there are many reasons why people go for a larger chassis (cockpit size being only one) would it be worth sizing your body on the 442 chassis.
This gives most people a direct fit for the body, or at least an upgrade opportunity in the future.
Widening the arches would give the car more of a modern stance. This would suit the choice of wheels/seats and interior that most people have (i.e.
carbon fibre, chrome, ally etc).
Looks and sounds promising, good luck
alistairolsen
| posted on 11/3/10 at 09:15 AM |
Mark, did you ever get around to doing anything with this?
My Build Thread
Triton
| posted on 11/3/10 at 10:27 PM |
Andy at Saturn Sports Cars now has the moulds as I have called it a day due to stuffed shoulder...badger him because it really is worth doing as such
a pretty shape.
