Author: Subject: Front cycle wing high
tks
posted on 19/6/06 at 07:24 PM Reply With Quote
hi all!
how much seperation do we put on the cycle wings? between tyre and metal plate and between metal plate and wing?
Any dangerous distances for stones???
Would not like the seeing of a stone picked up by the wheel cutting my wing in 2pieces...
Tks
EDITED: WOULD NOT
[Edited on 20/6/06 by tks]
andyharding
posted on 19/6/06 at 07:37 PM Reply With Quote
I have about 25mm.
miserableoldgit
posted on 19/6/06 at 08:01 PM Reply With Quote
Front wing clearance
I have about 250 miles at the moment!!
(That's the distance between Triton, who is making them in Cornwall, and the car which is in Telford)
Think that will be enough??
Youth and vitality are wasted on the young
tks
posted on 19/6/06 at 08:03 PM Reply With Quote
not funny
i asked for clearance not for travelled distance..
what do you mean to say?
Tks
Danozeman
posted on 19/6/06 at 08:40 PM Reply With Quote
25mm sounds about right to me. Or at least thats what mine will near enough be.
Think it depends on what look you want aswell. Closer the better in my book.
Dan
DarrenW
posted on 20/6/06 at 10:00 AM Reply With Quote
i used 2 lengths of hosepipe gaffer taped on top of wheel and bent the wing stays onto this. arch bonded directly to wing stays.
Hose was approx 3/4" OD (std home garden hose)
posted on 20/6/06 at 10:26 AM Reply With Quote
Sounds like you are having a bad day, tks!
My wings sit about 3cm over the tyres. It depends on how rigid your supports are (will the wing and/or its supports bounce against the wheel and tyre?) and if you can get the wheel off when you need to fix the tyre.
The second point is the main reason for not mounting the wing too close - it can stop you from removing the wheel from the hub.
hope this helps,
Wheel side
Wheel side
tks
posted on 20/6/06 at 12:15 PM Reply With Quote
nahh not completely true
its just i'm almost finishing the build.
and i'm sick that i live in a town where they have nothing!
i mean i can buy allot but the things i just need always i need to travel 60km for them.
Anyway thanxs for the info all, will take the dimensions given as a basis for mines..
thanxs ladies
Tks
posted on 20/6/06 at 12:21 PM Reply With Quote
Sounds like Ipswich...
Danozeman
posted on 20/6/06 at 12:49 PM Reply With Quote
True but Stowmarkets worse!!
Dan
