stevebubs
| posted on 17/7/06 at 09:13 PM |
Aerocatch Supplier
Anyone found the plush locking aerocatches cheaper than here...?
http://www.raceparts-direct.com
RazMan
| posted on 17/7/06 at 09:21 PM |
I think you will find that the price is pretty much standard wherever they are stocked.
I've used two pairs on my car and I must say they are top notch quality kit
Also worth mentioning is the fact that the flush mounted version can be installed without any nuts & bolts by 'sandwiching' with a grp
gasket over the top of the catch (on the inside of the bodywork) - and then bonded together with PU adhesive. The result is a very neat catch which is
practically invisible when painted.
[Edited on 17-7-06 by RazMan]
Raz
ayoungman
| posted on 18/7/06 at 09:20 AM |
Could you give me a diagram so that I can see if I can make use of them.
Ta
"just like that !"
irvined
| posted on 18/7/06 at 10:08 AM |
Rally design seemed to be the cheapest when i was considering getting them.
hth
http://irvined.blogspot.com
RazMan
| posted on 18/7/06 at 12:17 PM |
Ta
Here you go - Make the 'gasket' about 15mm bigger than the Aerocatch flange. Surprisingly simple, but it works
[Edited on 18-7-06 by RazMan]
Raz
