splitrivet
posted on 24/7/06 at 07:52 PM |
spigot bearing removal
Anyone know an good way of removing a Pinto spigot bearing, Im at me wits end with this B*****d.
Bob
froggy
posted on 24/7/06 at 07:55 PM |
il jump in here first,
find a dowel of very close size to the hole then pack the spigot bearing with grease then smack the dowel with appropriate hammer and out it pops !
Mr G
posted on 24/7/06 at 08:15 PM |
That's what's Supposed to happen - In reality your there for hours getting covered in grease swearing and hitting things
your not meant to be hitting.
Finally you pull out the dremel and grind it out.
John Bonnett
posted on 24/7/06 at 08:32 PM |
Yes, use the grease as a hydraulic fluid. What a fantastic idea. I shall file that away in my mind for use in the future.
John
jollygreengiant
posted on 24/7/06 at 09:21 PM |
Find a rawl stud (like a rawl bolt but with stud & nut) of appropriate size, Get several large washers that fit the stud. Insert rawl stud and
tighten nut (with washers fitted), then lever (preferably evenly with two opposing levers) behind the washers and hey presto out it comes.
locost spigot bearing removal tool No1.
Hope this helps. (PS when they have been REALLY stubborn I have used a gas axe to good effect).
Enjoy.
froggy
posted on 24/7/06 at 09:36 PM |
il remember that one too good one!
splitrivet
posted on 24/7/06 at 10:01 PM |
A few good ideas there, try em tomorrow,thanks lads.
Bob
Mike R-F
posted on 25/7/06 at 07:12 AM |
Try using Vaselene instead of grease (I'm talking about removal of a spigot bearing, here). I think it helps as its a bit thicker (getting into
all sorts of trouble now). A socket of the correct o/d with a extention bar inserted from the wrong end and a good, hard whack should do the job first
shot! I've removed a few & this approach always works for me
Marcus
posted on 25/7/06 at 08:07 AM |
A small bead of MIG weld shrinks the bearing case just enough too!
Marcus
Because kits are for girls!!
NS Dev
posted on 25/7/06 at 11:46 AM |
grease has always worked for me. Needs to be a very close fitting "dowel", really a spare input shaft is ideal, that's what I always
have used, they are great clutch alignment tools as well!
