laidbacklocost
posted on 6/5/03 at 08:49 AM |
What doner?
Can I use a sierra 1.8 cvh as my doner car?
Please help me quick!!!![](/images//smilies/sad.gif)
ChrisW
posted on 6/5/03 at 09:10 AM |
Yes, but you will need a couple of other bits too.
Chris
My gaff my rules
MK9R
posted on 6/5/03 at 11:04 AM |
Large with salad and extra chilli![](/images//smilies/tongue.gif)
[Edited on 6/5/03 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
westdown
posted on 6/5/03 at 12:26 PM |
sierra cvh
Ive have used the 1800 sierra cvh engine, so far so good, you will need to mod the sump and the top cover. As i have made chassis 4 inches wider and 4
inches longer i have also lifted the hight of the scuttle slightly this has helped. You will also have to make the transmission tunnell slightly wider
to get the engine/box as far back as possable. I have also cut the side out of the starter motor housing to clear the chassis to get engine right back
as far as possable. moving it this far back also means the gear stick is in a good position. You can also use the standard sierra engine mounts.
Hope this is of some help.
Dave:
I never could spall
[Edited on 6/5/03 by westdown]
