Slater
| posted on 14/8/06 at 10:26 AM |
Rollbar Shape? Opinions please...
What rollbar shape do I go for? I want a road car (MAC#1 ZR), not intended for track use, but don't want to rule out the odd track day. I guess
it's a compromise between, safety, weight, cost and looks. In the end it's personal preference, but just thought I'd get some
opinions on here. I have 2 options:
Basic rectangle
+ve's cheaper, lighter, More room in boot?
-ve's Less safe??
Rectangle with back braces?
+ve's Safer?? Stronger, would back braces help if you were hit in the rear?
-ve's could interferre with hinged boot lid, weight, cost
roadboy
| posted on 14/8/06 at 10:32 AM |
Backbraces are essential, a hoop without braces would just bend flat under the weight of the car dragging along bthe road. Braces would also add
strength to the rear in the event of a rear end shunt.
Regds
Ian
Jude Performance Services
iank
| posted on 14/8/06 at 10:35 AM |
back braces every time, with a cross brace if you want to be really safe. additional weight of back brace isn't much.
An unbraced single loop will fold up or break off in an accident making it about useless and just extra weight and cost over no bar.
Findlay234
| posted on 14/8/06 at 10:40 AM |
i may be bias but i quite like the luego velocity roll bar. its got quite a nice shape and pretty good bracing for strength.
http://www.luegosportscars.com/cars/velocity/pics/archive/pages/velocity5_jpg.htm
http://www.luegosportscars.com/cars/velocity/pics/archive/pages/velocity19_jpg.htm
Howlor
| posted on 14/8/06 at 10:42 AM |
Regds
Ian
I agree entirely. If you want even more strength for the odd track day you could have a removable diagonal brace into the passenger footwell.
smart51
| posted on 14/8/06 at 11:04 AM |
Keep the back braces to the sides and there is still room for a hinged boot lid. There is on mine.
Liam
| posted on 14/8/06 at 11:53 AM |
Rear braces should be a minimum. I'm having a diagonal too. Dunno why people with a single hoop bother to be honest - in all but the most
delicate of rolls it'll fold up and they'll still get smeared up the road.
I've got mine tapered in at the sides about 10 degrees and slanted forwards a-la Caterham which i think looks good. Can see it in my photo
archive.
Liam
Slater
| posted on 14/8/06 at 01:31 PM |
hmmmm, unanimous opinions, can't realy argue with that. Looks like I'll go for the back braces on safety grounds. I like Smart51's
idea so you can still have a hinged boot lid.
Thanks!
C10CoryM
| posted on 14/8/06 at 04:07 PM |
Also, two things I see often are roll bars that are too short, and no knee bars.
The rollbar needs to be 2" above a helmeted head for SCCA rules for a reason. With no helmet you don't need to crush your head, just
bang it on the concrete at speed and you're done.
The knee bar also helps reduce that chance by changing the angle of impact. For example in the velocity pics that were posted you have to draw a line
from the top of roll bar to the very front of the car (unless there is a hidden kneebar). This is the angle the car will land/slide and your poor
head has to be below that line. Adding a kneebar under the scuttle/cowl makes that line further up and gives more head room.
Maybe Im just a little cautious though. I snap rolled my truck into a ditch a while back and put the roof into the seat
http://www3.telus.net/public/corym/crash/s1.jpg
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
