RazMan
| posted on 19/8/06 at 08:59 PM |
Design Ideas Please
Once again I am having a design dilemma - my rear end is not covering all my chassis and I need to lower the bottom line a little. Trouble is how do I
do it?
Here's a pic of the body as it is now... (simulated grill mesh for the benefit of the image)
[Edited on 19-8-06 by RazMan]
Raz
RazMan
| posted on 19/8/06 at 09:01 PM |
and a possible solution? Basically I could tack on an extra panel below the diffuser and put mesh behind it.
(sorry about the crappy pic, althought it might look better in the dark at the moment )
Whaddya reckon?
Raz
TimC
| posted on 19/8/06 at 09:44 PM |
Honestly, I'd leave it as it is - don't see that as a problem.
In fact, I quite like to see a bit of chassis...
Chippy
| posted on 19/8/06 at 09:52 PM |
Would definately say that your second picture does look better. Would be better if it came down in one line, rather than in two steps though. Just my
opinion. Cheers Ray.
Ketchup
| posted on 19/8/06 at 10:09 PM |
can you fit a small ali panel onto the chassis that is exposed.. and paint it matt black
Ketchup
| posted on 19/8/06 at 10:10 PM |
sorry, that reads like im making an order, not a suggestion!
DIY Si
| posted on 19/8/06 at 11:02 PM |
Could you make a rear diffuser and wrap it up and around to the rear panel?
Sun Tzu, The Art of War
RazMan
| posted on 19/8/06 at 11:14 PM |
TimC - I had originally thought about leaving it as it is but after looking at a few pics I decided it had to change -0 it looks too much like a kit
car
Chippy - I played around in Photoshop and made a deeper panel as you describe but it would be difficult to engineer as the rear hinge is exactly where
the lower splitter is now.
Ketchup - (Hi mate ) A small panel to hide the chassis might work visually but I prefer to make everything functional whenever possible.
DIY Si - A diffuser is a good idea (functional too) I'll need to have a look at some examples to get an idea of what needs to be done. It may be
difficult due to the way the rear section hinges though.
Raz
Hammerhead
| posted on 19/8/06 at 11:28 PM |
i'd go the diffuser route too..........hellfire made one maybe take a look at his site??
| posted on 20/8/06 at 09:28 AM |
Fasten a piece of plate on under the chassis and bend it up to meet the bottom of the fibreglass panel then trim it to the contour of the panel and
paint it. It will be easier than adding onto the bottom of your panel in fibreglass.
chriscook
| posted on 20/8/06 at 09:35 AM |
You may find that if you widen a bit of MG-F bodykit it'll fit quite well.......
Would probably go for diffuser myself if the undrside of the floor is flat - be careful that you don't make it too steep though.
RazMan
| posted on 20/8/06 at 10:32 AM |
I'm pretty much convinced that a diffuser is the best way to go now.
As suggested, a plate attached under the chassis and bending up to meet the existing body with a number of strengthening ribs in the panel to get the
ground effect.
Like this (courtesy of Raw Striker's website)
Question - What material to make the ribs from ? Ally would be the best choice but how would I get the profile needed?
[Edited on 20-8-06 by RazMan]
Raz
gttman
| posted on 20/8/06 at 12:30 PM |
be careful that its still SVA complient.... but a rear difuser is definatelly the way to go IMO.
Andygtt
Please redefine your limits
RazMan
| posted on 20/8/06 at 01:29 PM |
Good point Andy - I was thinking that 15mm thick with radiused edges would be ok. I don't really want to have to make a mould, although
fibreglass would be better for a more rounded shape.
Raz
DIY Si
| posted on 20/8/06 at 04:22 PM |
Could you make it out of ally plate/sheet with the fins either welded on, or rivet on either T or L shape fins? Easy to shape and attach.
RazMan
| posted on 20/8/06 at 07:31 PM |
I have a feeling I might have to wait until after SVA before I do this - it's good to get all the ideas together though.
I will probably make some 15mm thick fibreglass fins and put captive nuts into the edges, then blend them into a curved fibreglass sheet made from an
ally template. The end result should be quite strong and reasonably light.
I'm presently fitting all the stainless mesh in various orifices around the car - it takes a surprisingly long time to get it all looking just
right.
Now onto the roof scoop ...... but that's another story
Raz
stulad
| posted on 21/8/06 at 06:54 PM |
omg as usual you have flagged up another good idea , damn you !!
maybe i should look at extending my rear end to hide chassis grrrrrrrrrrrr.
Raz I have added third brake light now (will add pics to my space ) and have started on rear light will talk to u soon cheers stu
RazMan
| posted on 21/8/06 at 08:08 PM |
[evil laugh mode]Muuahahahahahah
Raz
gttman
| posted on 21/8/06 at 08:15 PM |
Aint you finished the Minator yet?........ slacker.
Andygtt
