Author: Subject: Ali thickness?
MK9R
posted on 12/5/03 at 08:37 AM Reply With Quote
Ali thickness?
What thickness/gauge ali have people used for their tunnel and back panel?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 12/5/03 at 10:00 AM Reply With Quote
16g half hard same as in the book. We used some thinner stuff on a mates car but it rippled every time he touched it. You couldn't rub it without denting it.
yours, Pete.
Jasper
posted on 12/5/03 at 01:51 PM Reply With Quote
Same, bends and cuts loverly. Just used a jigsaw with coarse metal blade.
MK9R
posted on 12/5/03 at 01:53 PM Reply With Quote
it that 1.6mm?
Cheers Austen
RGB car number 9
www.trackace.co.uk
stephen_gusterson
posted on 12/5/03 at 02:08 PM Reply With Quote
Originally posted by MK9R
it that 1.6mm?
16 SWG = 1.6MM
STEVE
PS
make sure you get the right grade of alu or it will be hard to bend and shape.
I think its 3003 grade........
[Edited on 12/5/03 by stephen_gusterson]
posted on 12/5/03 at 02:49 PM Reply With Quote
...also = 1/16" inch, near-enough!
One of those useless things that catch my attention...
DJ
carnut
posted on 12/5/03 at 03:59 PM Reply With Quote
i used 1mm 20swg for all panels. I found that it was great to work with and saves a lot of weight.
kingr
posted on 12/5/03 at 04:28 PM Reply With Quote
IIRC tiger recommends 1mm
Kingr
givemethebighammer
posted on 12/5/03 at 06:34 PM Reply With Quote
used 1.2mm stuff from my local fabrication firm, cuts easily with a jigsaw and is solid too.
macbrew
posted on 12/5/03 at 07:26 PM Reply With Quote
Chassis stiffness for me !
I'll be using Ali for the side panels but for the seat back I've welded in 20 swg, bit heavier but a lot more solid and I think (hope) it will help stop the chassis twisting. Looking at the book, Riveted Ali looks a bit flimsy. I've also done the front end mods i.e. v brace, welded front bottom panel and triangulating the very front part of the chassis (forget the tube letters). I will also weld in 20 swg for the sides of the tunnel.
This (hopefully) will give me a stiffer chassis for not much weight.
Engine is a 1300 standard xflow - may not be as fast / quick as others but cornering is the thrill for me. 40 round a 90 is probably better than 100 round a 120 (and a bit safer)
I'm no expert, just my way of thinking. I'm sure you'll point out the error of my ways !
Great forum, learnt lots, need to learn more.
