davrus
| posted on 22/8/06 at 09:43 PM |
How do you tell the differance
Hi ya
With all thes sevens looking the same how do you tell them apart , is there an easy way to tell the differance.
graememk
| posted on 22/8/06 at 10:06 PM |
we are all sad anoraks
cryoman1965
| posted on 22/8/06 at 10:15 PM |
Easiest way is to ask the driver.
Or you could put photographs all over your bedroom wall, of all the different types available.
Then you can play name that 7 while in bed with your partner.
Assuming there is nothing better to do.
Seriously they all have subtle differences and its a case of looking and learning.
The easiest one to spot is the Cateringvan. As soon as the driver opens his mouth it will be obvious.
[Edited on 22/8/06 by cryoman1965]
DIY Si
| posted on 22/8/06 at 10:40 PM |
The easiest way is to look at the bonnet badge! It's the only way I'd know the difference. Too busy driving to give a balls about things
like that anyway.
Sun Tzu, The Art of War
andyps
| posted on 23/8/06 at 02:09 PM |
Westfields are easiest to spot because of the 'step' on the side along a line at teh lower edge of the bonnet - helped them be legal
rather than regarded as a copy of a Lotus/Caterham.
zetec7
| posted on 23/8/06 at 05:00 PM |
I'm afraid it's a hopeless task. With all the Locosts there are, bearing in mind they all look superficially the same, yet there are no
two exactly alike. Some homebuilts are using bodywork panels from a kit manufacturer (or from several, for that matter!), or copying different
designs that they like, basically they're like people. They all have the same shape, but they're all different....
JackNco
| posted on 19/9/06 at 08:53 PM |
erm...... westfiel has a ridge down the side.... and a different roll bar thats got 2 45° angles instead of a 90° bend
Dax have a strange roll bar
Robin hoods have more ally involved
MK have 2 bulges on the side of the front arches
Tiger cat e have a buldge at the front and no visable shocks. the avon has a scoop that looks a bit ditterent.
Thats jus from what ive observed and is by no means correct its more of a rule of thumb from what ive seen.
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
