| posted on 3/10/06 at 10:45 AM |
cycle wing stays
may need to make a set of these....
will 10 mm steel tube be sufficiently strong?
On the cortina uprights, I notice there are two holes vertically in line near the caliper, is the lower one also tapped to M8?
There is a third one at the front and my old stays use the front one and the upper of the two.
Marcus
| posted on 3/10/06 at 11:18 AM |
We used all 3 holes in the upright, and made a triangular mount, welding the tubes to this. Originally we used 10mm round bar for the tubes, this
proved very weak and the arches flapped like a good 'un, eventually breaking at the welds. Mkll was 3/4" round tube - these are far better
and have lasted 3 years so far.
Marcus
Because kits are for girls!!
| posted on 3/10/06 at 11:57 AM |
cheers - so as I thought, the third hole can be used.
the requirement for these is to make a journey of 70 miles
| posted on 3/10/06 at 04:49 PM |
The mounting plates on mine were 3mm but have broken twice. Have repaired and reinforced by doubling the thickness to 6mm . Will be making new ones
fron at least 6mm plate and heavy gauge metal for the rest , will double up on the part that bends around the wheel as one broke after 500 miles
Mark Allanson
| posted on 3/10/06 at 05:59 PM |
Mine are made of 10mm 18g erw round, its the transverse part of the stays which causes the cracking, so just do away with them
Mark Allanson
| posted on 3/10/06 at 06:03 PM |
..the only modification is a bit of 20g webbing as shown in red. I have had these on the road for 18 months and 6500 miles
