andrews_45
| posted on 19/11/06 at 06:33 PM |
Before I start my scuttle can andbody spare some tips?
I am planning on making a start on my scuttle tomorrow. I have an MK fibreglass affair. I'm planning to make a template out of stiff card then
do the dial mounting face in aluminuim. Nut sure how to fasten the whole assy to the chassis though? was going to rivet it down...
Any advise welcome, ta
| posted on 19/11/06 at 06:37 PM |
I used some short coach bolts to screw it into holes drilled into the chassis through the glassfibre scuttle.
Seems to work fine- the coach bolts have pretty course thread so a fair bit of grip.... Making a cardboard template for the dash is a good idea- I
think I had to make two or three in the end- but then I wanted a constant gap between the edge of the dash and the scuttle edge... stuff like
that's always trial and error...
DavidM
| posted on 19/11/06 at 06:51 PM |
I reinforced mine with aluminium strips bonded to the inside of the scuttle fixing flanges. I then bolted through these strips (and the flanges) into
rivnuts set in the top chassis rails. All of my electrics fuses and relays are under the scuttle, so I made my scuttle/dash as an assembly that can be
easily removed as a single unit.
Personally I wouldn't rivet it to the chassis as it will be a real pain to remove it again if you need access to anything.
Proportion is Everything
ReMan
| posted on 19/11/06 at 07:37 PM |
Rivnuts and screws with hard rubber strip to spread the load a bit, def a good idea to be removable
stevec
| posted on 19/11/06 at 07:48 PM |
Did mine in a similar way as ReMan. You can easily remove it if you plan ahead by putting plugs on you dash wiring.
Steve.
[Edited on 19/11/06 by stevec]
whitestu
I used rivnuts and large washers to spread the load. Be careful where you drill the holes in the scuttle & chassis.
On mine the scuttle needed to be pulled in quite a bit to line up.
I ended up having to open up the holes I drilled in the scuttle to pull it in line with the side panels
Stu
ianclark1275
| posted on 19/11/06 at 08:13 PM |
just on with that now.
i have a MK scuttle and used 2 rivnuts each side with bolts and washers
it tool 2 people to line the scuttle up with the edge of the chassis well.
i put some paint on the bolt heads and then lined it up and pressed down so the holes were drilled correctly without having to file it a lot.
you will find the scuttle will be on and off like a prom dress when lineing up the steering column etc..
attached is a MK being built, that how they have lined it up.
Clarky
ianclark1275
| posted on 19/11/06 at 08:22 PM |
Im just on with that now.
I have a MK scuttle and have used 2 rivnuts each side with bolts and washers.
It took 2 people to line it up neatly and then I put some paint on the bolt heads and placed the scuttle on it an could then drill the holes in the
correct place with out filing the scuttle.
You will find the scuttle will be on and off like a prom dress during the course of the build.
Heres how MK have lined it up on one of their cars.
Clarky
zxrlocost
| posted on 20/11/06 at 11:09 AM |
remember to leave a little overlap for the side panels
