omega0684
| posted on 30/11/06 at 08:52 PM |
silencer mounting
good evening all,
i have been off the forum for a while as i have been hard at work in my new job. but not only that i have also been hard at building my car to, (dont
worry boys im not letting the side down)
anyways i am at the stage now where i need to mount my silencer but i am unsure on how to go about it. i have put on a photo so that you can see where
i am going to mount the silencer,how have people mounted theirs, what types of bracket etc and what materials were used for the brackets
ATB Alex
locoboy
| posted on 30/11/06 at 09:05 PM |
Here you go.
Pictures courtesy of Hellfire (i think!) taken at Stoneleigh this year.
  exmount1
  ex mount2
Maybe it was Mr loo from on here?
Looks like as a result of your flared side panels your scilencer is quite a way away from your chassis/body so this method may not be appropriate.
[Edited on 30/11/06 by locoboy]
Locoboy
Jon Ison
| posted on 30/11/06 at 09:10 PM |
sorry no pics but I use a strap around the silencer then a small rubber bobbin with M6 threads sticking out each end, its what we use at work too
rubber mount vac pumps, anyone want any ? Can get a pic up tomorrow if you wish.
Humbug
| posted on 30/11/06 at 10:51 PM |
Here's mine:
Wide ali strap split in half part way - one half to clamp round the silencer, the other half bolted onto a Land Rover engine mounting rubber. The LR
engine mount is bolted onto a piece of angle steel which is bolted to the car from underneath
omega0684
| posted on 30/11/06 at 11:05 PM |
will that pass sva?
Humbug
| posted on 1/12/06 at 06:46 AM |
The strap is actually the second one (previous one was in two parts riveted together and it broke) but is basically the same as the one I had on for
SVA. I think because the strap is so thin, as long as you round off the edges you are OK
Danozeman
| posted on 1/12/06 at 06:47 AM |
MInes the same as humbugs. Alli angle bolted under neath with a silencer band mounted on a bobbin.
Many have gon through like that.
Dan
| posted on 1/12/06 at 12:36 PM |
quote: Originally posted by locoboy
Here you go.
That is most definitely ours. The only problem with mounting it as per the photograph above, is that there is no flexibility in the exhaust system
to allow for expansion and contraction, therefore it tries to expand where the silencer is clamped to the link pipe and it can end up blowing.
Phil
