Author: Subject: Front to rear brake bias on MOT roller tester??
NS Dev
posted on 17/1/07 at 02:48 PM Reply With Quote
Daft question, but taking the car to the garage on fri afternoon to check the brakes on the rollers pre-sva.
What % do I need as a front to rear comparison?
posted on 17/1/07 at 02:52 PM Reply With Quote
As long as the front wheels lock up before the back wheels that is all the SVA look for.
NS Dev
posted on 17/1/07 at 03:04 PM Reply With Quote
thought there was a load of calcs in the manual on C of G etc and the brake effort had to satisfy that lot?
If its just front before rear then no probs, I know it does that...............
Bob C
posted on 17/1/07 at 03:48 PM Reply With Quote
yep - load of calcs - designed to ensure front before rear on all surfaces (ice to dry tarmac). If your fronts lock first on dry tarmac & you have a bias bar (or nothing at all) you'll get through
Bob
MikeR
posted on 17/1/07 at 04:21 PM Reply With Quote
so my harness gets it first official outting - be careful with it, don't do anything silly, i don't want any stretching or blood on it ok!
(remember, i've been your passenger!)
do a search, i'm sure this has been covered before.
RazMan
posted on 17/1/07 at 05:17 PM Reply With Quote
My SVA tester told me that my car was overbraked on the rear calipers (std Sierra) and needed to tweak the balance bar - I still passed though.
Raz
Kissy
posted on 17/1/07 at 06:32 PM Reply With Quote
I set my bias almost fully front. On the rollers it passed no worries (helps that the MOT guy races monoposto, so is sympathetic to non-standadr stuff) The rollers were knackered on the second year so they did the road test using the accellerometer - for that they needed the vehicle weight (which I knew) so they calculated it as OK too. I'd let them know when you turn up - hopefully you won't have a station where they keep you away from the tester. Best bit was the emissions - mine were taken from a Laguna! Happened to be the nearest car to the emissions checker.
zxrlocost
posted on 17/1/07 at 11:52 PM Reply With Quote
dude when they checked my car he was very serious about all the measurements and readings
go with bog standard pads and make sure your fronts lock up first on your private test road your 90% there
chris
NS Dev
posted on 18/1/07 at 08:40 AM Reply With Quote
Ok, cool.
Thanks all.
My roll pin on the bias bar may prove "compliant" enough to allow the neccesary adjustment!
chockymonster
posted on 18/1/07 at 09:34 AM Reply With Quote
Ok, cool.
Thanks all.
Have fun with that!
My tester spent a good 10 minutes making sure the roll pin was all the way through!
NS Dev
posted on 18/1/07 at 09:43 AM Reply With Quote
How?
RazMan
posted on 18/1/07 at 09:47 AM Reply With Quote
I didn't even have my bias bar locked for my test! The tester was happy with it though.
Raz
NS Dev
posted on 18/1/07 at 09:53 AM Reply With Quote
I have the aforementioned "roll-pin", and I also have an alloy cover/footrest, which I want to fit over the pedal box, but I'm not sure whether if I fit it he will fail it through suspicion!!!!
