Author: Subject: Bonnet shaping and bending advice?
want2race
posted on 30/1/07 at 05:10 AM Reply With Quote
Firstly how did everyone cut it ? Does anyone know the starting dimensions needed?
and secondly, how did you bend it? I just ordered a piece of .060" ALi today and it was $60 so I would rather not stuff it up if possible
~J
Humbug
posted on 30/1/07 at 07:23 AM Reply With Quote
Do a search on here, e.g.
http://www.locostbuilders.co.uk/viewthread.php?tid=57208&page=1
http://www.locostbuilders.co.uk/viewthread.php?tid=45423
http://www.locostbuilders.co.uk/viewthread.php?tid=13185
http://www.locostbuilders.co.uk/viewthread.php?tid=12355
just for instance!
Surrey Dave
posted on 30/1/07 at 08:24 AM Reply With Quote
bending!
My first bonnet was bent around my BOC Argoshield cylinder.
The bonnet I made last year was bent around a wooden telegraph pole as I no longer have a BOC cylinder.
posted on 30/1/07 at 08:36 AM Reply With Quote
I glued together some cardboard sheets (art shop stuff) to make a template. Fitted the scuttle and nose cone, then taped the card over and marked it out. I cut out a large hole for the downdraft carb, then glued on more card around the hole until it fitted the air filter properly. Took it off, made allowances for bends and folds, then taped it onto the ali sheet and marked out.
I made the 90-degree bends along the side using a sheet metal bender at my friend's business (a very large machine!). The curves were bent around a gas cylinder.
I didn't try to fold the front and rear edges - life's too short - I simply glued edging on.
You can click on the 'WWW' button below to see how it turned out...
cheers,
[Edited on 30/1/07 by David Jenkins]
JAG
posted on 30/1/07 at 08:37 AM Reply With Quote
Mine was bent around my knee
.........very very carefully.
I had planned on using a local telephone/telegraph pole but found it much easier with my knee. The best bit is you don't do all of the bend in one go hence you can adjust the line of it as you work along the length of the bonnet.
Pictures in my archive will show how it worked out
Justin
scutter
posted on 30/1/07 at 08:40 AM Reply With Quote
I used a piece of floor vinyl for the template, it droops when heated and the forms the curves when cold.
ATB Dan.
steve m
posted on 30/1/07 at 08:50 AM Reply With Quote
Mine was bent on the car with the scuttle, and nose cone supported with so as to avoid distortion, my Dad lay on the bonnet, while i went each side and vary carfully bent the 2 "wings" downwards, by using a piece of wood to spread the load, I had taken the carb off, ass the hole can be left till last,
i only managed to crease one bit, and over the years, this crease has been mostly polished out
this bending process only took a couple of hours
mark chandler
posted on 30/1/07 at 10:19 AM Reply With Quote
Bit of old 2" plastic drain pipe for me !
I measured the middle of the curve from scuttle to nosecone and marked on the ali sheet (oversize) then bent around the pipe.
Next was to lay it on the bodywork and mark out the cut for the scuttle & nosecone, I cut the scuttle edge first then the nose cone so I had a snug fit.
Next was to strap the bonnet down tightly and mark out the body line bends, the using some box tube and clamps align with my line and bend over (I used a lump of 2"x 2" wood as a hammer to not mark anything), then just trimmed.
Louves are stamped in, I knocked a tool up out of scrap to do this. its the lump of metal on the scuttle. Rescued attachment louves stamper.JPG
James
posted on 30/1/07 at 11:39 AM Reply With Quote
Plotter paper template.
With 1" returns bent on the edges.
Drew the bend lines on the ali (peel- off vinyl covering) then bent it around a long length of 2nd hand (yuck!) 4" waste pipe clamped in the workmate.
HTH,
James
907
posted on 30/1/07 at 05:19 PM Reply With Quote
Hi.
When bending metal there's always a certain amount of spring back, so it needs to be bent
round something smaller than the finished rad required.
It also needs to be bent more than 90 deg.
You need also to get the middle of the bend right as the ends will follow. It's easy to "unbend"
but it's harder to get more bend in, if you follow, but don't over do it.
So when you over bend, you can then gently pull the edge of the sheet back, till the radius and angle
comes right, again get the middle right first and the ends will follow.
Practice with a piece of scrap. A foot square or so.
Depending on the hardness of the material you will get a different amount of spring back.
I started with a sheet that was too big and trimmed it to size after bending.
Not sure if you can get hold of a cardboard carpet tube like I did. I think it's a case of use what you can.
Hth
Paul G
