Author: Subject: Fitting front wings..... ?
Jon Ison
posted on 20/2/07 at 06:46 PM Reply With Quote
My old wings where fastened with 4 cap head bolts, of course this means drilling the wings.
I don't want too drill my new ones, what have people found effective too fasten them too the wing stays ?
PAUL FISHER
posted on 20/2/07 at 06:53 PM Reply With Quote
PU ADHESIVE,such as bodyline or tiger seal,you will not get them off though in the future,not without breaking them.
Jon Ison
posted on 20/2/07 at 07:00 PM Reply With Quote
Its that good ? What sort of time have you got too slide them into position ? Enough ?
posted on 20/2/07 at 07:05 PM Reply With Quote
Jon, thats all we did... you have about 1 hour to get them as you like them (age of PU allowing). Old PU sets quicker!
We drilled holes into the support (AS HERE) halfway down the page, roughed up the fibreglass and away it went. When set it's very difficult to move them.
Phil actually clipped a roadside post at Cadwell with the nearside arch... slight crack in the arch but it held on! We used TEXFLEX PU adhesive (body panel adhesive) £6.00. HTH
desyboy
posted on 20/2/07 at 07:06 PM Reply With Quote
I welded a strip of metal the same size as the cycle wing mount, each side of the main mount, this gives you a mounting area of about 3" x the width of the cycle wing and drilled about 8 holes in each piece of metal, done this at both mounting points on both cycle wing brackets then had them powder coated, then stuck the cycle wing down with sikaflex pushing the cycle wing down letting the sikaflex ooze through all the holes. job done
Des
snapper
posted on 20/2/07 at 07:08 PM Reply With Quote
you can buy a stud welded to a perforated square plate, buy 4, tiger seal/sikaflex them to the underside of the arches then weld a flat plate to the arch stay, drill that and bolt up underneath. The stud can be ground down to be level with the lowerpart of the wing stay and therfore the nut also should not be lower than the bottom of the wing stay.
Removable and adjustable, if you weld the plate to the front of the stays for the SVA you could weld a bit more to the back afterwards and have the cycle wings further back.
[Edited on 20/2/07 by snapper]
I eat to survive
I drink to forget
mookaloid
posted on 20/2/07 at 07:40 PM Reply With Quote
Another vote for PU adhesive here - I don't think I'll ever get my wings off
Rudy
posted on 20/2/07 at 07:57 PM Reply With Quote
excuse me, what is pu adesive?
hellfire may you post a photo of your wings supports? You have sierra uprights, is it true?
Thankyou
Sorry about my English
Chippy
posted on 20/2/07 at 10:36 PM Reply With Quote
I used Evo's "Serious Stuff", made no mods to the wing stays just stuck them on to 1" x 3mm strap, no drilling, and boy they will never come of. I tried after fixing the first one, and actualy moved the suspension, wing was unmoved. HTH Ray
Rudy
PU is short for polyurethane. HTH Ray
[Edited on 20-2-07 by Chippy]
bigrich
posted on 20/2/07 at 10:50 PM Reply With Quote
another vote for wurth bond and seal
will stick sh-t to a shiny shovel
posted on 21/2/07 at 12:59 PM Reply With Quote
Thankyou
We do indeed have Sierra uprights. Have a look in the build and rebuild sections of our website. They should contain pictures of the wing supports.
Phil
Rudy
posted on 26/2/07 at 07:55 PM Reply With Quote
on your very nice web site I found this photo, but I do not see weel how is attaced, do you have other photo? Or may you take a photo? Thankyou Rescued attachment P6161468.jpg
