Author: Subject: Mirrors - How far out, height etc.
The Doc
posted on 18/3/07 at 10:04 AM Reply With Quote
As a 'rule of thumb', what are the critical specs for the location of mirrors? How far away from the body and at what height?
Anyone help?
stevec
posted on 18/3/07 at 10:09 AM Reply With Quote
If its for SVA they will have to be positioned so the fields of view in the picture below are achievable, apart from that I dont think it matters where you put them.
Steve,
[Edited on 18/3/07 by stevec]
bigrich
posted on 18/3/07 at 10:35 AM Reply With Quote
make sure that the rear wings don't obstruct the view to rear too much from drivers seat
high on the scuttle/bend area seems to work for most people
Dusty
posted on 18/3/07 at 12:04 PM Reply With Quote
If they extend beyond the vehicle side line, ie beyond the front or rear arch they must be sprung/knock back type. There are rules for size of reflecting surface also.
graememk
posted on 18/3/07 at 03:54 PM Reply With Quote
i called the sva tester about this and he told me to stand next to the drivers seat take one step away from the car then 10 paces back behind the car then put something on the floor (sand / gravel) then sit in the car and see if you can see it, if you can you should pass the mirror test
Paul (Notts)
posted on 18/3/07 at 04:44 PM Reply With Quote
as in pole A on the above diagram.
