Author: Subject: Nosecones and Pintos - common problem?
Jumpy Guy
posted on 21/7/03 at 01:40 PM Reply With Quote
I have a standard book chassis, with a 1.6 Pinto fitted, and I'm getting to fitting radiator/nosecone.
Recently bought a used nosecone, and I dont know where it originally came from.
Problem- the nosecone sits on ok, but just fouls the top flywheel on the engine.
So, is this a common problem? Options too horrible to think - engine mounted too high, non standard nosecone, aaarrrggghh!
chrisg
posted on 21/7/03 at 09:27 PM Reply With Quote
OOps!
Someone should have pointed this out to you before.
Have you chopped the sump?
Even with the sump chopped it's high, you need more height in the chassis (bit late for that now) or a higher nosecone or a bulge ala Tiger.
Look at the front of the Tiger kits, you'll see what I mean.
How does the height of the scuttle compare with the top of the rocker cover?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mix
posted on 22/7/03 at 07:29 AM Reply With Quote
I have a similar problem with a book chassis, MK nosecone and Zetec. The plan at the moment is to raise the nosecone by adding two lengths of 25mm rhs to the chassis top rails for the length of the nosecone. This allows enough room to get the engine in and the 20mm of chassis protruding below the nose will be obscured by the number plate. I plan to make the bonnet deeper accordingly however if you plan to use a bought bonnet it would be easier to add RHS from the front of the chassis to the rear of the scuttle.
Good luck Mick
Jumpy Guy
posted on 22/7/03 at 01:12 PM Reply With Quote
Never mind the width.... what about the depth!!??
Thanks! maybe not as fatal a problem as I thought.........
Further thought - if you use RHS as spacer under the nosecone, but a deeper bonnet, were you going to have a deeper sidepanel at the front to hide the RHS?
Hmmmm....
theconrodkid
posted on 22/7/03 at 04:52 PM Reply With Quote
i had the same prob on mine,cut the edge off the peice behind the pulley or make a slightly smaller 1as long as it covers the valleys in the pulley its ok
who cares who wins
pass the pork pies
Jumpy Guy
posted on 22/7/03 at 09:26 PM Reply With Quote
eh? you cut the flat bit off the pulley?
the verticle bit at the back? I suppose you're right, you only need a smaller lip that stops the belt teeth falling off the back, just sounds a bit yeeeehaaaaa!!
I like it!!
And less dicking about with bodywork...
Do you have photos? would be mucho appreciated
