Author: Subject: tax disc holder + glunbg on number plate
posted on 12/4/07 at 12:43 PM Reply With Quote
panning to make 5 small holes in my plastic screen (thought it was glass) to attach tax disc holder - any reason why not to do that?
Also using pu adhseive to attach rear number plate - any reason not to to that? (I will be able to drill 2 holes for plastic bolts at the top but no access further down due to tank/boot floor)
graememk
posted on 12/4/07 at 12:56 PM Reply With Quote
on the back why not pu a number plate holder on from a boy racer shop then stick the plate to that
graememksva4
graememksva4
[Edited on 12/4/07 by graememk]
cadebytiger
posted on 12/4/07 at 01:00 PM Reply With Quote
Why not use a motorbike tax disk holder?
posted on 12/4/07 at 01:03 PM Reply With Quote
boy racer plate holder = excess weight and spending cash
only problem I can tbk off is if the reflective plate backing starts to peel .... may use rivnuts + plastic bolts.
already have the tax disc holder - did consider bolting to scuttle side but it is not flat enough (or maybe between the seats).
graememk
posted on 12/4/07 at 01:10 PM Reply With Quote
boy racer plate holder £5 tube of pu £8?
posted on 12/4/07 at 01:21 PM Reply With Quote
Fit the rear no. plate with self tappers and bolt the tax disc on the rear bulkhead between the seats
esn163
posted on 12/4/07 at 01:44 PM Reply With Quote
we PU'd our rear number plate straight onto back panel with no problems.
Also fitted a motorbike style tax disk holder into side of the passenger footwell to try and keep it out of the way if it rains etc.
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
dilley
posted on 12/4/07 at 01:57 PM Reply With Quote
you can buy proper double sided numberplate tape, i've allways used it with no problems.
posted on 12/4/07 at 01:58 PM Reply With Quote
except that I alredy have the pu type stuffs
so a cople of bolts and gluey stuff seems to be the way.
