i've got the straight across one, not the jpe one, but they're moulded so the top section is flat. it has a return underneath for
mounting, but you need to trim a lot out to make it flexible enough to bend to the curve on the top of the scuttle.
so far with mine, i've got it down to 3 maybe 1" wide tabs on the bottom return, and then it'll probably get 2 bolts through either
end.
as for the carbon bit, it's got a bit of imperfection in the weave, and a few bubbles, but nothing major
it's not fluke quality, but then it's not fluke price.....you pays your money, you takes your choice
hth
tom
