Markp
posted on 30/7/03 at 06:12 PM |
Windscreen supports
i've been on the road for around a month with nothing more than a wind shield, and I joke you not, it can get cold.
I've gone back to the book to look at windscreens.
It says the windscreens support brackets are 5mm thick.
Can this be right?? If so how do you bend them to marry up with the scuttle??
Mark
mranlet
posted on 30/7/03 at 08:04 PM |
a rubber mallet and some elbow grease
-MR
Aussie
posted on 30/7/03 at 09:43 PM |
i was told you need to reinforce the scuttle if you are going to fit a full windscreen otherwise the fiberglass cracks.
Is this true? if so how do i add extra support to it?
This month up for grabs I have a copy of G. Wayne Miller's new book - Men and Speed.
So check out http://www.nick-kjaer.com for more info on how to enter this free monthly competition.
Dick Axtell
posted on 1/8/03 at 10:01 AM |
Windscreen supports
The Caterpork example is made in 6.0mm Alu. I'll post a sketch (when I find it!!).
[Edited on 1/8/03 by Dick Axtell]
mranlet
posted on 1/8/03 at 02:32 PM |
Reenforcing the scuttle might depend on the angle of the windscreen...
I would suggest to simply take the supports a little farther down and mount them to the exterior edge of the outside footwell members.
-MR
