Author: Subject: What's The Difference Between a Hank-bush and a Riv-nut?
posted on 26/5/07 at 10:10 PM Reply With Quote
Obviously other than the name!
mangogrooveworkshop
posted on 26/5/07 at 10:32 PM Reply With Quote
hank bush is for sheet
rivnut is for tube however it can be used for sheet as well
the_fbi
posted on 26/5/07 at 10:41 PM Reply With Quote
Hank bush is "splined" and an interference fit into a hole with itself only on one side.
Rivnut is around both sides of the hole and crimped onto it.
Bob C
posted on 26/5/07 at 10:52 PM Reply With Quote
rivnut is a 'blind' fastener so it's useful on tube - hank bush you need to access round the back.
Bob
stevebubs
posted on 27/5/07 at 12:22 AM Reply With Quote
907
posted on 27/5/07 at 06:28 AM Reply With Quote
Hank bushes are almost as strong as conventional nuts.
Rivnuts are a weaker option.
They both have their uses, but in highly stressed parts of the chassis I prefer to weld (Tig) in threaded bosses,
as large drilled holes in the chassis are weak points. (IMHO)
Paul G
