Author: Subject: Exhaust Heat Shield.
The Baron
posted on 31/5/07 at 07:36 PM Reply With Quote
I have made a heat shield from 2mm thick aluminium; I have the usual edge trim around the outside.
I also have 50 25mm holes in the heat shield, do the holes have to have edge trim, or be flanged inwards?
Or… can they be left as plain holes
The Baron
flak monkey
posted on 31/5/07 at 07:44 PM Reply With Quote
You dont need a heat sheild for sva anyway.
Sera
http://www.motosera.com
davrus
posted on 31/5/07 at 07:47 PM Reply With Quote
Dont think you can leave them as they are as they will not be radiased enough, edge trim or tap them inward seems the only option.
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
davrus
posted on 31/5/07 at 07:48 PM Reply With Quote
Or like flat says , leave it of untill you have passed s.v.a.
The Baron
posted on 31/5/07 at 07:52 PM Reply With Quote
ok, its staying off until I get a pass, I guess I just cover the mounting with edge trim, and fit a couple of nut overs.
cheers,
The Baron
