Author: Subject: Rear Wheel Arch
907
posted on 1/8/07 at 04:46 PM Reply With Quote
Rear Wheel Arch
Hi All,
I'm on holiday at the moment so I've a bit of time to spend on the car.
Yesterday I bashed some ally, today I bashed it some more.
I'm quite pleased with the way the arches are coming along and
with a bit of luck I'll have the other side screwed on tomorrow.
That's another bit to add to the filing, rubbing down, and polishing list.
Sorry, but I couldn't resist posting a pic.
Atb
DIY Si
posted on 1/8/07 at 04:58 PM Reply With Quote
Looking good there! Have you a finish date in mind, or just it's done when it's done?
Sun Tzu, The Art of War
posted on 1/8/07 at 05:00 PM Reply With Quote
Paul,
Is it true that your forthcoming sausage fest is really a "bring a polishing rag" party?
907
posted on 1/8/07 at 05:21 PM Reply With Quote
Nooooooooooooooooo
Sausage meet is a "Lay A Brick" party. (the well)
2008 is "The Year of the Rag"
Atb
Paul G
posted on 3/8/07 at 09:52 AM Reply With Quote
The Well.
Did you find anything else out about the history of the well or are you still looking into it? It would be nice to hear your findings or your plans for it, it's an interesting feature worth documenting or preserving in some form. Not so dramatic but in our back yard I took down a lean to and removed the concrete base it was on and underneath was a drain carved from stone about 2' across with a cast iron grid which is now exposed and acts as a useful soak away.
DarrenW
posted on 3/8/07 at 10:31 AM Reply With Quote
Im loving the car and the craftsmanship. Very nice indeed. Also love the back 'yard'. I wish i had a small one like that
907
posted on 3/8/07 at 11:49 AM Reply With Quote
Hi Pete
It was possibly dug around 1910 when the house (+ 3 others) was built.
In the 50's the mains water came to the village and a single tap was installed in the front
garden near the road for the 4 houses. I still use it to wash the car.
I have cleared the area around the well, turfed it, and put up a fence to act as a wind break. (see pic)
Now I need a brickie.
You can't lay bricks can you?
It should make a nice sun trap area to sit in when it's done.
__________________________
Hi Darren,
Don't know about the craftsmanship. It still needs a lot of rubbing down where I welded in a crescent
shaped piece on the outer rad.
That garden isn't all mine. That's next doors front lawn over the lavender.
Thanks for the comments.
Atb
