Dale
| posted on 6/8/07 at 04:57 PM |
FENDER BUCK
I have been making my bucks to make one of fenders for my car. I still have to deside where to vent out the the air that gets trapped in the front
between the wheel and the nose (thinking shark gills down the side of the fender). And to get the slope behind the front wheel just right as I think
it needs a bit more room behind the wheel like the morgons.
The rear fender is the question though. I am still just mudding them up and realised that I have an inward curl to the fender at the front and back
so pulling the glass off of it is going to be hard/impossible. The fender is symetircal so it can used for either side (only one buck and less work
for me.) I will need to make adaptors to match the boot-trunk to the fenders but that will be easier than trying to make two fenders the same.
When the fenders are mounted I will have to have a cut in the inward front side to clear the suspension mounts but that should not be too much of an
issue. To pull the piece off of the buck would i be better to cut the piece down the center and re glass them back together or should it flex as I
plan to do 2 or 3 layers of glass and then when pulled stiffen it from the inside with more layors.
Any hints.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Dale
front
Dale
Dale
| posted on 6/8/07 at 04:58 PM |
side
Dale
twybrow
| posted on 6/8/07 at 05:09 PM |
I would try the flexing/wedges/compressed air approach first. The problem is you may not get it off, and you may end up damaging the part. The cut it
and rework option may be the only option available. You should be able to get a good repair if you have used a thick gelcoat layer.
Fred W B
| posted on 6/8/07 at 05:18 PM |
Just make a split mould, I.E the mould is made in two (or more) pieces with flanges bolted together . Be sure to include male/female registers in the
flanges so the mould pieces go back together in exactly in the same place
Fred W b
Dale
| posted on 6/8/07 at 05:27 PM |
The problem is I have not been planning on making a mold, just the buck and glassing my part right over the buck.
I know this will require me doing a skim coat of body fill over the finished piece, but it should make the process simpler in the long run and only
intend on making one body- except maybe accident repair.
Dale
Dale
