The Doc
| posted on 12/8/07 at 03:25 PM |
Covering Brackets and 'Ears'
OK I'm now getting into covering up the stuff at the front. I have my nut covers. No problem covering up the lock-nut etc on top ball joint,
track rod end etc. but:
Do we need to cover the top of the ball joint itself?
Do we need to deal with the suspension bracket edges. If so what will stay on such a piddling amount of material?
Do we need to worry about covering the nut below the top ball joint?
What about the bottom ball joint nut?
I guess that some of these can't be contacted by the inspector's sphere
Avoneer
| posted on 12/8/07 at 04:34 PM |
If you can see a nut or edge, cover it anyway.
You can get really small rubber u trim that you stick on with silicone for the bracket edges.
Might have a bit in the garage if you want it.
Pat...
The Doc
| posted on 12/8/07 at 07:45 PM |
Thanks Pat you have U2U
Mike
Alex B
| posted on 13/8/07 at 09:34 AM |
Anyone got a pic of the sphere in action?
Alex
Avoneer
| posted on 13/8/07 at 04:41 PM |
Here you go:
Black Cat
| posted on 13/8/07 at 08:43 PM |
Some people have used the rubber wheels from model cars. They come in various sizes and fit on the bottom of the front suspension over the damper
adjustment.
Avoneer
| posted on 13/8/07 at 09:22 PM |
The tyres are to cover the adjustable platform that has very sharp edges.
Pat...
Mark.
| posted on 13/8/07 at 09:46 PM |
And the best thing to cover them there ears is a bobble hat
