Author: Subject: What size are these tail lights?
Fred W B
posted on 14/8/07 at 08:26 AM Reply With Quote
As title, can anyone confirm the size of these tail lights?
If I know the taillight size I can scale the other dimensions I need to help position the body cut outs on the rear of my body pattern.
Fred W B
70rear
70rear
posted on 14/8/07 at 08:44 AM Reply With Quote
can you not assume the number plate is standard UK size and use that to work out the other dimensions?
(I predict we get a "What size is this number plate?" post soon )
Fred W B
posted on 14/8/07 at 08:45 AM Reply With Quote
that would work, so "What size is this number plate?"
Also, at a guess, would those exhaust pipes be 3"?
Fred W B
[Edited on 14/8/07 by Fred W B]
twybrow
posted on 14/8/07 at 08:47 AM Reply With Quote
I am pretty sure I have those lights in a box at home. I will measure them tonight. They are from SVC (is that right?) and are the same size as the 'hamburger' style ligths.
Fred W B
posted on 14/8/07 at 08:48 AM Reply With Quote
Thanks twybrow, would be much appreciated.
Fred W B
posted on 14/8/07 at 09:18 AM Reply With Quote
They also use them on some buses.
Though you'ld have to get the tape measure out at the bus stop pretty quickly unless you live near a depot!!
posted on 14/8/07 at 09:40 AM Reply With Quote
They certainly look like the lights SVC supply - check here about half way down the page...
http://www.s-v-c.co.uk/lights_rear.html
Dia. 122.5mm
Confused but excited.
posted on 14/8/07 at 11:23 AM Reply With Quote
I though it was the digits on a number plate that had to be a certain size, not the plate itself.
I have just been out to measure some, as I thought I might assist.
Guess what? Three cars, Rover, Renault and a Ford and they all have different size plates; 3&15/16, 4&7/16 and 4&3/4.
The numbers in the photo do not look standard, so that's no help either.
adithorp
posted on 14/8/07 at 12:10 PM Reply With Quote
Hella lamps. Part No2BE 964 169-071
122.5mm diameter 82.5mm deep.
Adrian
twybrow
posted on 14/8/07 at 01:11 PM Reply With Quote
Looks like I dont need to measure 'em up tonight after all. They are deffo the ones half way down the SVC page.
907
posted on 14/8/07 at 03:45 PM Reply With Quote
I have a pair of those.
In the end I fitted the SVC flat oblong LED units as my arches are quite tight to the wheels.
£18 + p ?
Paul G
Fred W B
posted on 15/8/07 at 06:18 AM Reply With Quote
Thanks for the info guys
Fred W B
Fred W B
posted on 15/8/07 at 02:39 PM Reply With Quote
Rereading the post, I now see that I missed that 907 is offering me the same lights to buy.
Thanks for the offer, but I plan to use period style "landrover" type smaller lights
Fred W B
907
posted on 15/8/07 at 04:04 PM Reply With Quote
No problem Fred.
As you are in SA the post was aimed at anyone really that clicked the link to SVC and were contemplating buying them.
I tend to go to shows and see stuff I fancy, then see something I like more at the next show.
At one stage I was going to fit square 2CV headlights, so I bought a pair with the intention
of refurb'ing them and having them chromed, Westfield style.
Like loads of stuff they now sit on the "items to fit" shelf in the garage.
I'll have a clear out one day.
Atb
Paul G
