Author: Subject: exhaust fumes
jason4x4
posted on 11/9/07 at 11:55 PM Reply With Quote
exhaust fumes
with roof off i seem to get exhuast fumes sucking over the back of the car and into the cab at speed,, is this normal and is there a cure , exhaust points out the back at the moment,
anyone else had this?
WWW.ALLCARCLUB.CO.UK
LBMEFM
posted on 12/9/07 at 06:00 AM Reply With Quote
Exhaust fumes
The arodynamics of the car are sucking fumes back in, thats why some sports car manufacturers fit draft reduces behind the seats. Try fitting one, available from www.softbitsforsevens.co.uk or 01798813389 alternatively fit a side exhaust
JAG
posted on 12/9/07 at 07:49 AM Reply With Quote
I never get this problem but I have a side exit exhaust system - like most Se7en type cars.
What car is this?
Justin
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 12/9/07 at 01:07 PM Reply With Quote
Same, never had this issue?
What car is this?
2b_pablo
posted on 12/9/07 at 01:50 PM Reply With Quote
sure its not a small leak under the car?
posted on 12/9/07 at 04:28 PM Reply With Quote
I'd be more inclined to think the smell was coming from the front of the car....
jason4x4
posted on 12/9/07 at 10:27 PM Reply With Quote
seems i should not try to be different and go for side exit, back to the workshop,,
a mate said it seems to be more of a fuel smell and as no leak found suggested a bigger air filter as it may be overfueling,??????
