iscmatt
| posted on 22/9/07 at 04:10 PM |
Bonnet vent pics
Today i have fitted my new bike carbs from boggs, they are awesome!!! Much stronger sound and a lot more responsive when dippping the right hand pedal
though i'm yet to go for a drive.
The only thing is i now have a hole in my bonnet where my old carb air filter stuck out.
Instead of buying a new bonnet i'd like to put some vents in but not to sure of a design and so...
I was hoping that people could post some pics of their vents, hopefully the pic will show where the hole is, just the filter isn't there
anymore!!
Thanks!!
worX
| posted on 22/9/07 at 04:16 PM |
Put a NACA duct in it's place - should be roughly the right size and that way you could direct it to feed air directly to your filters!
sorry - no photo...
MkIndy7
| posted on 22/9/07 at 04:17 PM |
Have you cut a new hole in the side of bonnet to feed the carbs with air?
If not you could make some ducting to them and put a filter in the hole thats already there.
Scoob
| posted on 22/9/07 at 04:38 PM |
Would a fiesta/escort rs turbo bonnet vent fit there?
big_wasa
| posted on 22/9/07 at 06:56 PM |
Cut a hole on the other side and put mesh behind them both
iscmatt
| posted on 22/9/07 at 10:55 PM |
This is the sort of thing i was thinking of, but the shape of the hole is a bit boring, i would like something a bit different and was looking for
some inspiration, looks like i'll just have to sleep on it
PAUL FISHER
| posted on 23/9/07 at 03:00 AM |
You could do a smaller version of this westfield,and put some black mesh behind.
will121
| posted on 23/9/07 at 08:51 PM |
had the same problem when i converted to bike carbs on my CVH i ended up making a air box to draw air from the existing hole in the bonnet as didnt
want to make another whole in the side of the bonnet for a sausage type filter, ive got a NASCA type bulge to fit at a later date if required for
additional cold air.
will121
| posted on 23/9/07 at 08:56 PM |
with NASCA scoop sat in possition on bonnet to cover whole
| posted on 25/9/07 at 09:31 AM |
i've got two scoops:
see here: see here
make me an offer just toget shot of the things.
there is always the locost option of B&Q vent
  view from above
