mr henderson
posted on 27/9/07 at 07:41 PM |
duratec 2.5v6 or Zetec 2.0?
I can use either in my project, and it seems to me that the duratec is the best bet, more power, no cam belt problems, alloy block, more modern
design
I would be interested in the opinions of others, though
TIA
posted on 27/9/07 at 07:44 PM |
Bigger the better???
AndyH
2.0 Duratec not an option?
MkIndy7
posted on 27/9/07 at 08:03 PM |
Two exhausts and mounts etc to buy or make for the V6.
Two cylinder heads if anything needs replacing, seals, head gaskets faster cam's etc
The V6 is no doubt slightly heavier and physically bigger as well.
Not that there a downer on the V6... just things to consider.
mr henderson
posted on 27/9/07 at 08:09 PM |
I'm looking at Mk2 Mondeo donors so no, the 2.0 duratec isn't an option. Thanks anyway
[Edited on 27/9/07 by mr henderson]
posted on 27/9/07 at 08:29 PM |
Neither. Fit a bike engine............
Phil
chrisg
posted on 27/9/07 at 09:15 PM |
If I could have put money on what you'd say Phil!!!
cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
RazMan
posted on 27/9/07 at 09:37 PM |
Personally I'm biased but my Duratec V6 is pretty good. 200bhp with a few basic mods and there's always the possibilty of a turbo or two
It's probably one of the lightest V6's around and mates nicely with the MT-75 or MTX-75 gearbox for transverse applications. (I've
got a spare box or two as well)
I have a base map if you need one and if you need any more info just shout
[Edited on 27-9-07 by RazMan]
Raz
posted on 27/9/07 at 10:09 PM |
It will not mate up to the MT75. The MT75 uses the old Ford bolt pattern so will fit Pintos, Crossflows, Zetecs, CVH's etc, but not the newer
Duratec engines. You need the Jaguar S type box and sump for RWD applications.
I reckon lots more people would be using them if in Locosts etc. if gearbox availbility was less of a problem.
[Edited on 27/9/07 by MikeRJ]
worX
posted on 27/9/07 at 10:25 PM |
I can't wait to see your twin turbo set up Raz!
I am with Phil! - stick a Bike engine in there and have more fun than you know whats good for ya!!!
DIY Si
posted on 27/9/07 at 10:37 PM |
It may be a light V6, but it doesn't make it light! I can pick up a zetec (just) put the V6 is far too much. Although it is a fairly nice
design, but tuning parts are a little thin on the ground compared to the zetec. As said, just llok to Noble for the possible power outputs, as they
use a twin turbo version of the V6, albeit with some internal mods.
Sun Tzu, The Art of War
RazMan
posted on 27/9/07 at 10:58 PM |
Quite right Mike - I seem to remember I got that wrong recently too (senior moment obviously )
Tuning parts are indeed a bit thin on the ground but you can find a few bits and pieces on the US Contour forums. Apparently fitting ST220 cams will
give the 2.5 litre engine quite a power hike and the intake manifolds from an ST200 (or US SVT) is very effective.
Removing the secondary butterflies improve the breathing a bit as well as removing all of the emmissions related stuff.
The standard water pump can also be ditched and replaced with an EWP, releasing a few more ponies.
Hmmm I doubt it will be twins but you never know
Raz
Chippy
posted on 27/9/07 at 11:03 PM |
As a confirmed V6'er, there's no contest, the lovely sound of a V6 on full song, cracking. With four pot its just any chav machine, a long
f*rt. Bike engines are just great, in bikes. Ray
iank
posted on 27/9/07 at 11:07 PM |
mr henderson claims to be building a 'MEC' if that means a Mid engined car then gearbox won't be a problem use the MTX75 from the
Mondeo.
In which case v6 every time if you have room - it's all alloy so not a lot heavier than the zetec.
You'll spend a lot of money getting a 2.0 zetec up to the same power the 2.5 duratec has as standard, so no tuning parts required unless you
'need' to go past 200bhp (ish).
Anonymous
ned
posted on 28/9/07 at 07:36 AM |
There are tuning parts available if you know where to go (or have a big enough wallet!)
Mountune have built nat asp race engines based on the 3ltr jag v6 (a derivation of the 2.5 duratec) at over 400bhp and this was a year or two ago..
Ned.
beware, I've got yellow skin
posted on 28/9/07 at 08:19 AM |
Whilst a V6 does sound 2 cylinders short of a real engine, I'd agree with our Phil. See the rear of your's on the next lap....
Chippy
posted on 28/9/07 at 10:44 PM |
Come now Steve, why would you want to see my rear. . But as I run something OVER 220 BHP, could you even keep up. Cheers Ray
posted on 29/9/07 at 06:11 PM |
So that works out about what........ 110bhp per tonne??? Keeping up would be no problem whatsoever. We'd even give you a head start
posted on 29/9/07 at 08:22 PM |
Phil
Another hijack, bike engines just don't get anywhere near a V6 for power and torque..
And how about the individuality of the car with a V6 in it? Go for it!
RazMan
posted on 29/9/07 at 08:33 PM |
Yeah, wot he said
Bloomin girly hairdryers pah!
[Edited on 29-9-07 by RazMan]
Raz
posted on 30/9/07 at 06:31 PM |
Phil
You so need power and talk in a car that weighs next to nothing... ours generates nearly 400bhp/tonne (more if you're talking flywheel bhp). Who
needs torque on such a light car?
I thought that's what 7's were for? Quick and nimbleness...
Chippy
posted on 30/9/07 at 10:17 PM |
Hellfire you miss the point entirely. The car may be light, (Ermm! maybe not mine), and nimble, but it's the quality of the sound it makes
that's just as important. Now while you may just loooove wearing a helmet and ear plugs, some of us love the sound of a real CEC engine, fours,
sixes Hmmm!, and eights. Not all of us want to blast round a track at warp nine. I even have a radio in mine, which as long as I don't hit the
loud pedal too hard is great. Cheers Ray
mr henderson
posted on 4/10/07 at 05:48 PM |
V6 Duratec acquired today, thanks for all the advice. Whole car (P reg Ghia) for £500 in excellent running order, FSH, less than 100,000 miles, and
plenty of sellable bits too.
RazMan
posted on 4/10/07 at 07:44 PM |
Nice one! Is it an ST24 or just vanilla flavour?
If you stumble on any performance goodies for it, give me a shout - I will do likewise
Raz
mr henderson
posted on 4/10/07 at 08:22 PM |
What's wrong with Vanilla? I like vanilla especially with some fresh baked apple pie
On a more serious note, though, it's just the ordinary 167BHP (guess that's more than most BEC's though).
I'm not plannng any modifications at the moment, but I will certainly draw you attention if I see any tuning bits on offer
