Ian Pearson
| posted on 2/10/03 at 09:14 PM |
Filler
For those of you UK based folk who have made molds for their fibreglass bits, what filler did you use, and what did you use to seal the filler prior
to laying up the fibreglass?
Mark Allanson
| posted on 2/10/03 at 10:08 PM |
I havent made my own GRP parts, but I have made bonnet scoops before when fitting 2.3 V6's to Mk1 escorts in my youth (when RWD escorts wre 2 a
penny)
I used standard body filler and polyurethane paint - apparently it is impervious to polyester resin and sort of acts as a release agent in its self. I
used brush on release agent over the top and rubbed out the brush marks out of the competed scoops using 1000 wet and dry
Ian Pearson
| posted on 3/10/03 at 05:20 AM |
Thanks Mark,
May be going to Exeter if I can get the time off work. May see you there?
Cheers for now, Ian.
Mark Allanson
| posted on 3/10/03 at 07:05 AM |
Me and Ian will be there
Simon
| posted on 3/10/03 at 08:49 AM |
Ian,
I made my side panels, rear panel, front and rear arches and scuttle a follows.
For the wheel arches I used 2 sheets of MDF and scribed a line that was about 1/2" bigger than the tyre radius. Then I cut a slot following line
with a jigsaw.
I then slotted ally sheet into holes and using ordinary plaster of paris and a former shaped the plaster into the corners to give the curve down the
sides.
Rear arches and scuttle done same way but rear arches have one "square side" (to attach to body) and scuttle used another form for the
bonnet recess.
I used a layer of grease (vaseline and sunflower oil mix) that was essentially wiped off.
Side panels were ally sheet and 1"sq used as a former likewise greased and wiped off.
See pic below to give you a better idea.
Simon
stephen_gusterson
| posted on 3/10/03 at 01:28 PM |
I used ordinary body filler.
CFS fibreglass supplies (who are in cornwall methinks) do a 3 or 4 KIL0!!! tub for a tenner. Dont waste money on Halfords little tins!
I sealed the surface by using ordinary WATER BASED wood varnish.
See my fibreglass section on the web site
flip
| posted on 4/10/03 at 05:54 PM |
It is possible to use normal plaster and then paint it with a 2K sealant. plaster is great to work with as it is cheap and easy to form. best talk
to your resin supplier and i am sure they will advice you which sealer to use.
After using the 2K sealer, fill in all the small imperfections with normal body filler.
what you don't forget today, you will forget tomorrow.
suparuss
| posted on 4/10/03 at 11:51 PM |
i would second what mark suggested, i made a bonnet scoop cos id never used fibre glass before so thought id have a go, made me plug out of ply and
filled it up with car body filler, u-poll do easy 1 and smooth seven (i prefer the smooth, its harder to sand, but that makes it easier to shape if
get what i mean, hard to sand too much off) and sealed it with polyurethane moisture curing, which is used for several industrial things like boat
building, repairing hulls etc. we use it at work to seal molds for cast stone. cfs sell it but it is listed as g4 sealer varnish.
russ.
