matt.c
| posted on 5/12/07 at 06:25 PM |
Bonnet catches
I have these bonnet catches
LINKY
But they dont come with fitting plans
Anyone got any plans for me before i make a mess of fitting them!
Matt
[Edited on 5/12/07 by matt.c]
caber
| posted on 5/12/07 at 06:45 PM |
I didn't get plans with mine either so I guessed with the first one so that the catch was directly above the rubber bit and had it stretch when
it was closed about 1/4". seems to work they have not come loose so far while driving.
Caber
myeates
| posted on 5/12/07 at 07:05 PM |
hi i have still got the fitting instructions will try email them to you if you like
flak monkey
| posted on 5/12/07 at 07:29 PM |
Try rs, stock code: 288-8464. You want the dimensions for the small ones.
Put the holes 2mm closer together than on that pic, so 29mm not 32mm.
Sera
http://www.motosera.com
myeates
| posted on 5/12/07 at 07:53 PM |
hehe beat me to it was strugling to do that
bob
| posted on 5/12/07 at 08:15 PM |
I used the plans from hellfires website, did a test on a lump of wood first worked a treat once you make a template up for holes from the self tappers
i used in the wood.Image deleted by owner
| posted on 5/12/07 at 09:09 PM |
SVA BONNET CATCH TEMPLATE
Agh - Bob you neat me to it....
Just print the plans....
Regards
matt.c
| posted on 5/12/07 at 10:05 PM |
Cool
Many thanks.
DaveFJ
| posted on 6/12/07 at 10:22 AM |
I got a scrap of ally sheet and drilled the mounting holes, then tested that the catch worked properly at that spacing (took a couple of goes til I
was happy) then i used the ally as a drill guide
Dave
