locoboy
posted on 14/10/03 at 09:04 AM |
sierra master cylinder
Can the reservoir be removed from the sierra master cylinder? its the one with 3 unions on it and the fluid level sensor.
It probably can be removed but its the practicallity of refitting it that i need to know about.
Locoboy
westdown
posted on 14/10/03 at 10:28 AM |
Reservoir remve/fit
Yes it can be removed .It is held in by two rubber seals, just give the reservoir a hard pull and it will pop out. To refit clean and lube seals and
push back on
Dave
posted on 14/10/03 at 11:38 AM |
if its that easy i may try it myself, theres a layer of sediment in mine! couldnt see any screws so didnt try...
Mark Allanson
posted on 14/10/03 at 08:44 PM |
Fill the cylinder with fluid, put blankers in the union holes, press the pedal hard and watch the reservoir fly into orbit!
posted on 14/10/03 at 08:46 PM |
does that mean it could happen on the move?! doesnt sound very fun...![](/images//smilies/sad.gif)
Mark Allanson
posted on 14/10/03 at 09:40 PM |
no, the pistons move forward and shut of the inlet holes - boring
