mr T
posted on 2/2/08 at 11:40 AM |
Type 9 gear set upgrade
Thinking of upgradeing a type 9 gear box with a quaife clubman gear set or a bgh 2.8 long first gear . Both sets cost approx £700 is it a good upgrade
and is it worth the money any help please.
turbodisplay
posted on 2/2/08 at 11:44 AM |
They are ment to be good for 275hp.
One cheap upgrade is to change the top cover with a sturdy piece of alloy to sto the case from flexing. It will add a bit to the hp rating as the gear
teeth remain in better contact.
Darren
SeaBass
posted on 2/2/08 at 12:06 PM |
The top cover locates one part of the selector mechanism. How do you overcome this issue with a piece of alloy?
turbodisplay
posted on 2/2/08 at 12:12 PM |
The maincase cover is pressed steel, as such is weak.
Not the tailcase.
£61 from deamon tweaks
Darren
[Edited on 2/2/08 by turbodisplay]
mookaloid
posted on 2/2/08 at 12:18 PM |
I believe quaife make a top cover which presumably takes this into account.
Mark
SeaBass
posted on 2/2/08 at 12:28 PM |
Not the tailcase.
Darren
Have you ever taken a type 9 apart??
I know the maincase cover is pressed steel - as I said it has welded onto the underside of it a component that locates part of the selector
mechanism...
NS Dev
posted on 2/2/08 at 01:47 PM |
Darren
No they are not rated to 275hp, that's the HD kit not the clubman one, and the HD one is a lot more money as it replaces the mainshaft which is
a very expensive item!
j30fos
posted on 2/2/08 at 04:33 PM |
Mines a BGH E7 and its just cost me £970 its rated to 280 it will just cope with the saab lump
procomp
posted on 2/2/08 at 08:54 PM |
Hi if running over 250 HP you will need to move up to a Quafie / TRANX straitcut box rather than a BGH with helical gears if wanting reliability
aswell.
Cheers Matt
