Piledhigher
posted on 13/2/08 at 01:19 AM |
roll bar clamp
All,
I need some feedback from the forum on a universal roll bar clamp system I am working on. See pictures below.
The clamp is ~50 mm (2" wide. The bracket can be drilled to mount water bottles, cameras, fire extinguishers, weights, ect.
Your feedback on the design and potential uses would be appreciated.
Cory
Atlanta, GA USA
[Edited on 13/2/08 by Piledhigher]
Simon
posted on 13/2/08 at 02:13 AM |
Had me concerned for a sec there. When I read title, I assumed it was a clamp to hold roll bar to car
As for suggestions, why make the bar clamp part from third sections when two will do. Two sections, 1 hinge would be the way to go, with rubber
backing to protect roll bar paint and provide damping for any cameras mounted.
HTH
Simon
Mr Whippy
posted on 13/2/08 at 02:16 AM |
na I think it kicks ass
nice one
Potential uses errrr machine gun or rocket launcher?
Howlor
posted on 13/2/08 at 07:41 AM |
Kids car seat mount, transform in to3 seater?!
iank
posted on 13/2/08 at 08:54 AM |
It needs some rubber to stop it chafing (fnarr fnarr).
Is the aluminium thick enough to tap? If so that would be more aesthetically pleasing than the big nylocs - obviously not as strong.
As for uses.
- Bulletcam (right up to professional video camera) mount
- luggage rack fixings
- Roof rack (for those with a full cage)
- Gun rack mount (sorry cheap crack at southern USA stereotypes)
- Spotlight mount (assuming you're aiming at the offroad/dunebuggy market as well as the 7's
p.s. how much are you thinking of selling them for?
[Edited on 13/2/08 by iank]
Anonymous
dhutch
posted on 13/2/08 at 09:02 AM |
A bit like a doughty clamp then?
- Available in std, slimline, and lightweight versions. In a varity of configiations, for 50mm nominal diameter.
- If you concerned about paintwork, just place a turn of gaff around the bar before hand.
http://www.doughty-engineering.co.uk/cgi-bin/trolleyed_public.cgi?action=showprod_T57120
Sorry to an arse, but it does seam like we're reinventing the wheel.
- Why not just do a bulk-buy on 100 doughty's and resell them. Unless this is just a design project for the yourself.
Daniel
DarrenW
posted on 13/2/08 at 09:15 AM |
I like the 2 wings at the top that also mount the bracket but not sure about the third lower one.
Overall its a neat idea.
posted on 13/2/08 at 12:01 PM |
Daniel
not necessarily - if you can make these clamps for 1/10 th price of doughty clamp you may be onto a winner.
dhutch
posted on 13/2/08 at 12:25 PM |
Im not saying dont do it. But at 40pence each (doughtys are £4 max) your never going to be raking it in.
Im just saying is all.
Daniel
John Bonnett
posted on 13/2/08 at 01:31 PM |
quote: Im not saying dont do it. But at 40pence each (doughtys are £4 max) your never going to be raking it in.
Daniel, where did you get the £4 price from?
I've just checked and they are £18.80 each plus carriage and VAT.
John
[Edited on 13/2/08 by John Bonnett]
Piledhigher
posted on 14/2/08 at 02:02 PM |
clamps
All,
Thanks for the feedback.
Iank, I agree that the nylocs are not attractive. I could go with shorter bolts and use barrel nuts to improve the looks.
The cost is still being worked out. A lot will depend on the fasteners used. The SS bolts and nylocs are more expensive than the extrusion.
The 1/4" thick mounting bracket is overkill, I agree. I am sourcing 1/8" thick 6063 aluminum for that part now.
I am also contemplating making this in a plastic extrusion to reduce costs.
Cory
thomas4age
posted on 15/2/08 at 03:58 PM |
I use a clamp from my drumkit, it's normaly used to mount one of the Tom drums to the Rack that surrounds the kickdrum.
it's the black one in this picture. made by the Osan brand, but there are also others, they're not very expensive and very strong, quick
release and since the rack tubes are normaly cromed they won't damage you rollbar!
it fits an early sylva striker perfect!
Grtz Thomas
If Lucas made guns, Wars wouldn't start either.
