Author: Subject: R1 Clutch depressed too far
ChrisS
posted on 17/2/08 at 08:35 PM Reply With Quote
Whilst adjusting my R1 clutch the other night i seem to have over depressed the clutch and its permanently engaged.
Does anybody know whether its possible to dis-engage it without draining the oil and taking off the clutch cover.
Coose
posted on 17/2/08 at 08:41 PM Reply With Quote
You won't have to drain the oil, but you will have to take the clutch cover off to pop the spring back.
Spin 'er off Well...
ChrisS
posted on 17/2/08 at 08:44 PM Reply With Quote
Surely if i take the cover off, all the oil will fall out i thought having never takenit off before the the oil level came right up into the clutch cover plates area?
nitram38
posted on 17/2/08 at 09:01 PM Reply With Quote
I have modified my clutch arm to give a longer stroke and stop this.
I have a matched wilwood master and pull type slave.
After the freeplay is removed from the clutch, my slave will operate the clutch, but not past it's stop.
Slave (pull type) with freeplay taken up, viewed from back of engine:
Clutch lever with no freeplay taken up:
Extra arm welded on opposite side. Original arm still connects to return spring:
[Edited on 17/2/2008 by nitram38]
Adam
posted on 17/2/08 at 09:52 PM Reply With Quote
Nope... I took my cover off today without draining the oil. Mine is a 2000 R1.
Adam
